BTW...DO NOT USE HEAT such as a torch!!!!
It will warp the bearings in the hub and then you'll have to spend around 60-75 each on new hubs. Generally, these don't ever go bad on 94-04 Mustangs. I've seen one go bad and when I got the rotor and hub off, I saw someone in the pas, heated it because there was a burn mark on the spindle shaft that holds the bearing. Big NO-NO!!
