anyone know the answer to this please help
  • Thread starter Thread starter smallstang393
  • Start date Start date Nov 22, 2004
smallstang393
75
  • Nov 22, 2004
first let me say i have done a lot of searching on this subject.
a powersterring bracket that moves p\s up to a\c location on a 351
and no asp or motorsport has this and march is the only one i've seen but i cant bank (249.99) just to move up p\s .If anyone knows a company or has this setup please tell me how so i can move it up and delete a\c
86T-Top
553
Dublin, PA
Nov 22, 2004
  • Nov 22, 2004
I haven't done this so I could be wrong but I will give it a shot. It is my understanding that the 351 uses the same a/c p/s bracket as the 302. But it uses an addapter plate to mount that bracket to the 351 block. If this is true why not just get a 302 a/c pump eliminator kit and mount it to the adapter plate (the one that is used to mount the a/c p/s bracket to the 351)
Mario.
MrKwik
1,008
Kansas City, Kansas
Nov 22, 2004
  • Nov 22, 2004
Ford Motorsport DOES make a kit for this.....sorta. Heres what ya need. Get the part number M-8511-A50, which is the A/C delete kit for a 5.0. It comes with a little aluminum bracket that bolts to the head, a steel bracket that bolts to the front of the pump and the water pump and the nessecary bolts. It looks like this...
Then get ford motorsport part number M-8511-A351. That is the 351 version of that bracket (the black bracket on the front of the pump in the pic). The other bracket and hardware is the same between both engines. Check for sure to make sure that second number is just the bracket but Im pretty sure it is. I got my M-8511-A50 from a ford dealer and it was $50 but I saw the same one in Halcombs latest catalogue for $39. Dont know what the A351 bracket costs but I would give Halcomb a call and see if they have it.
smallstang393
75
  • Nov 23, 2004
thank you thank you thank you
Tragedy struck. Need help.
  • 78 Mach1
  • Oct 13, 2025
1974 - 1978 Mustang II Talk & Tech Nov 21, 2025
Bronco2fan
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 19, 2026
squeak93
Engine HELP - 351W Based Build Under Stock Hood
  • thinkfaster
  • Oct 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
