  • 1994 - 1995 Specific Tech
ANYONE O-RING THEIR HEADS?
  • Thread starter Thread starter haulbalz
  • Start date Start date May 3, 2004
haulbalz
448
  • May 3, 2004
right now i'm in the process of getting my heads o-ringed.. anyone done this? also, who all is unning o-ringed heads? do they keep from blowing head gaskets better than stock. the reason i ask is i am getting ready to add a supercharger. how many psi can i go with my combination witho-ringed heads and stud mounted heads? Thanks guys!
baglock1
The Bartender
6,612
Space Coast, FL
May 5, 2004
  • May 5, 2004
You one of those guys who just tosses money at the car with no idea why?
Since it sounds like you're already having the machine work done before researching it, does it really matter?
haulbalz
448
  • May 5, 2004
actually yea, i just wanted to know who all did it after blowing a head gasket... and if it helped from futher blown head gaskets. a$$
95GTvert[bv12]
1,792
Lake Tahoe, NV
May 5, 2004
  • May 5, 2004
yeah it will help with head gasket issues but i have a friend that blew a head gasket with ringed heads with 15psi off a novi 2000 so it helps alittle
haulbalz
448
  • May 6, 2004
thank ya
stang_gt_1994
2,723
Powder Springs, GA (30 min. from Atlanta)
May 6, 2004
  • May 6, 2004
If your still running the stock block and about to add a blower your block will crack before your head gaskets blow with a good tune. Head gaskets are kinda like insurence. I would just get some cometic head gaskets and not even O ring. But its your money.
moneypit94
1,723
Macomb, IL
May 6, 2004
  • May 6, 2004
You guys are crazy... I went through 3 sets of headgaskets before i finally o-ringed them and haven't had a problem sence. I still think if Jesse would have o-ringed his heads his car would still be turbocharged. Yes im on a stock block and yes the car was tuned.. I can post dyno graphs to show you.. If your going to be putting boost to the heads i recommend o-ringing them. If your going to pushing a ton of boost i suggest getting the block o-ringed too.
There are so many guys right now getting away from forced induction because they are blowing headgaskets. I would be willing to put money down that if they would have o-ringed there heads they wouldn't stray. (talking about the guys that haven't had there heads o-ringed)
haulbalz
448
  • May 6, 2004
thanks for the info bud!
95GTvert[bv12]
1,792
Lake Tahoe, NV
May 6, 2004
  • May 6, 2004
you can't o ring both it's one or the other....I may be wrong but i am pretty sure you can only do heads or block
moneypit94
1,723
Macomb, IL
May 6, 2004
#10
  • May 6, 2004
  • #10
yes, you can do both...
I
2000 GT Mustang - Transmission Cooler to Radiator o-rings
  • Iwarrior
  • Oct 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 4, 2025
Iwarrior
I
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Suspension Rack and Pinion Teflon seal /o-ring
  • ursixx
  • Dec 28, 2023
2K
1994 - 1995 Specific Tech Apr 21, 2024
WhiteCobra95
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
