Dropped my T5 out today to install my King Cobra clutch setup. While lowering the T5, I was hit in the forehead by a small roller bearing. All I can think of is that it came out of the speedometer cable hole. Does anyone have an idea???
Realmongo said:Dropped my T5 out today to install my King Cobra clutch setup. While lowering the T5, I was hit in the forehead by a small roller bearing. All I can think of is that it came out of the speedometer cable hole. Does anyone have an idea???
That IS a piece that comes out of the reverse light switch, if you removed it. The only other thing it could be is a roller out of your pilot bearing in the back of your crank, because it has small rollers like a u joint roller does. might want to check that if you didn't remove your reverse switch on the side of your tranny.Realmongo said:It looks just like the small roller bearings that come out of the cup of a universal joint.
BERT306 said:That IS a piece that comes out of the reverse light switch, if you removed it. The only other thing it could be is a roller out of your pilot bearing in the back of your crank, because it has small rollers like a u joint roller does. might want to check that if you didn't remove your reverse switch on the side of your tranny.
Mustang5L5 said:That is the roller bearing that fits between the input and mainshaft iside the t-5. SOmetimes it's tricky to assemble those parts so novices tend to drop a few inside the trans.
You can see where it goes in the service manual
http://www.ttcautomotive.com/English/media/pdfs_autogen/T-5_Service_Manual.pdf
Page 56, figure 6-11 Part # 66A
There are 15 of these bearings between the two shafts
It might be from the pilot bearing.PoopDawg said:Yep... It does look like the loose roller bearings in the end of the input shaft.. They ride on the main shaft like said. But... Like Tmoss said.. how the hell did they get out of the trans? lol. Only other thing I can think of is a pilot bearing roller, but that roller is a little too long to be a pilot bearing roller.
Edit: Thought that was a quarter next to the roller.. but it's a dime...It might be from the pilot bearing.
Mustang5L5 said:When you reassembly, use vasaline to hold the rollers in place.
