....and if so, what are you using for your intake tube? I'm going with a 75mm T/B and 90mm Lightning MAF on my Blown 4.6 and am wondering what everyone's using for an intake tube? So far it either looks like a C&L or a custom home made set up?
Nope, you are correct. It’s an Allen REV I. I’m going with their base kit that they’ll equip it with a 9psi pulley and SCT chip. From there I bought a set of 36lb injectors, 90mm Lightning Mass Air and am working on getting a 75mm throttle body (probably a BBK unless I can find an Accufab cheap?). I realize that all of it is overkill, but just in case I plan on spinning the blower a little harder later on, I might as well have all the supporting parts in place before hand. It’ll be topping off a forged 18cc short block and ported PI heads.prsrizdgt said:Hey Gearbanger, what's up? With my 1st generation Allen where the TB gets mounted in the back by the firewall, I was able to use the stock rubber tube from the air box to the MAF, then found a flexible hose in the McMaster Carr catalog which worked to the TB. I am going to the 90mm this winter. From reading your posts, I am confident you are running an Eaton, but I do not know what type, Saleen, Allen, or what.
Keep in mind....this is a Cougar, not a Mustang. The stock MAF on it is only 70mm with a big old aluminum center post running down the middle of the sample tube. I realize that it's not moving enough air yet, to warrant a 90mm, but If all goes well, it eventually will, so why not go all out if I’ve got to replace it anyway? It's not like a throttle body in the sense that you would lose torque and/or horsepower by going to big. Besides that, a 90mm Lightning MAF is a very inexpensive piece and I'll be having the SCT programmed to work in conjunction with the 36lb/hr injectors along with it.2002BLGT said:IMO...thats not enough rwhp to need the LMAF yet , save your money and run the stocker with the 36 lbs injectors , upgrade to the LMAF when you need 42 lbs injectors ......
Gearbanger 101 said:Keep in mind....this is a Cougar, not a Mustang. The stock MAF on it is only 70mm with a big old aluminum center post running down the middle of the sample tube. I realize that it's not moving enough air yet, to warrant a 90mm, but If all goes well, it eventually will, so why not go all out if I’ve got to replace it anyway? It's not like a throttle body in the sense that you would lose torque and/or horsepower by going to big. Besides that, a 90mm Lightning MAF is a very inexpensive piece and I'll be having the SCT programmed to work in conjunction with the 36lb/hr injectors along with it.
....bought the 90mm Lightning Meter and the 36lb/hr injectors as a package deal before I even made the thread. $335.00 shipped to my door. Sounded reasonable enough to me.
Gearbanger 101 said:Nope, you are correct. It’s an Allen REV I. I’m going with their base kit that they’ll equip it with a 9psi pulley and SCT chip. From there I bought a set of 36lb injectors, 90mm Lightning Mass Air and am working on getting a 75mm throttle body (probably a BBK unless I can find an Accufab cheap?). I realize that all of it is overkill, but just in case I plan on spinning the blower a little harder later on, I might as well have all the supporting parts in place before hand. It’ll be topping off a forged 18cc short block and ported PI heads.
Most of the guys on the TCCOA forum figure that with this set up it should be good for 340-350rwhp.
Any suggestions…what did you think of their tune with the kit? I plan on going for a dyno tune later on, but I live in Ontario, Canada so driving to California to have it done right away is out of the question.
