Anyone running a spool in their car?
Quikstang
846
Orlando FL
My car is down until summer, putting another tranny and rear end in it. I am thinking about just ditching all the posi - bull and throwing a spool, some good axles and maybe stepping down to 3.55's. I have heard bad things about spools on the street in the rain, but my car is light duty, weekend warrior... There is probably a 5% chance I will ever get caught in the rain on drag radials... Just seeing if anyone else has chose the relatively cheap route on building a rear end.
p.s -- oh yea, and what is the difference in a regular spool and a mini-spool?
C
A mini spool replaces the internals of the differential to achieve a full time lock. A full spool replaces the whole differential with what's basically a solid chunk of metal. A full spool is stronger. I have never owned or driven a vehicle with a spool, so I can't say from experience, but I have heard it's not so great for anything but a straight line.
it's easy, i had to remove the steel shim behind each spider gear for it to totate back together with the 2 extra friction plates..test fit that pin before installing into the car, i had to grind the flatspots all the way to the top and bottom of the pin, on both sides
~Mark~
