It looks like you need a stall converter very badly. A new cam would also help you out. Have you ever dynoed your car?rustang94 said:does the kit come with alum. or cast heads?
I have gt-40p cast heads, the tubular gt-40 intake, fuel regulator, 1.6 RR, 65mm throttle body, 3:55 gears, underdrive pulleys, full mac exhaust, stock cam, and an aode with a shift kit. And I ran 14.2 at 99 mph and a 60 foot of 2.0
rustang94 said:I'm thinking of a 3000 stall and a stage 1 trick flow cam.
Green 94 5.0 said:$3000?? ouch.....might want to take a look at the holley systemax 2 for nearly $1000 less.
a buddy of mine has the fox throttle body setup and systemax 2 intake under his stock hood. he did have to remove the blanket though. you might also want to take a look at trickflow. i understand they are offering a kit now too.JimTMich said:I think the kit goes for about $2700 if you shop around. The kit even comes with strut tower brace, y303 heads, gt40 intake, 65mm tb, inlet adapter, stainless shorty headers, 1.7 roller rockers, manifold cover, 3.55 gears bolt kit,. It's not a hi reving kit like I understand the systemax kit is, but I haven't looked into it much. I talked to holley and they said that the kit won't fit under the stock hood of a 94-95.
