Anyone Use Ford Racing Short Throw Shifter And 2post Bracket
Steeda Tri-Ax FTW: http://www.americanmuscle.com/steeda-triax-shifter-mt82.html?source=igodigital
I have heard the stock shifter isn't bad provided the bushing is replaced. At a minimum replace the bushing. If you still aren't happy, then replace the shifter too.
Steeda bushing: http://www.americanmuscle.com/steeda-shifter-bushing-1112.html
The Steeda bushing is an $80 part. It may work for you and save you a lot of money.
But if you don't like the shifting still, then getting the Tri-ax will still save you money even with the bushing cost factored in.
Total Steeda cost with bushing and Tri-ax: $330.
Ford Racing cost: $470.
I installed the Steeda shifter bushing (black), and I am happy with the results!
If you just want a more solid shifter feel then go this route, as the stock shifter bushing is just hard foam.
I personally was just looking for a more solid-feeling shifter, as I personally don't like short throws, and this fit the need.
Yes it uses the same reverse lock-out. You have to push down and up to the left. It's a little stiffer though so it's harder to accidently do it. I don't have a picture of it handy, but no one would even notice the difference in looks other than you have a different shift knob and the shaft is skinnier.
get the Barton, the Ford shifter and bracket are Barton pieces with their logo on it and priced much much higher. I have a Barton shifter and 2 post bracket and it is a great setup, precise shifts are the norm now
