The TFIII is a good cam, the carb will like the short duration and high lift, it could make more power with a tighter LSA ( f/i rollers.. leave the pulses to the carb a little weak).. but it will work fine!! disagree on the cfm for the carb.. (well actually, this way) If it wont see higher rpm ( 4000 and up..) then the smaller 650 will be good for street driving.. but the higher the rpm and the bigger the cubes and heads.. the more power in the upper rpm ranges.. and then the bigger carb is needed!!
your combo doesnt sound like a .. go to the store .. type!! SOOoooo... the 750 CFM will rock!! Keep the jets stock.. run it a few times and then probably need to bump UP the jets a few sizes.. but run it FIRST!! Jetting is important... but dont confuse fuel to air flow!! cool??
Like the man said... run it.. have fun, and stop sweating all the small stuff that you can work out over time and drives!! It is almost impossible to get a perfect suggestion over the forums, when there is a bazillion different ways that the engine got built!! Cool??
example... Vic Jr intake?? Race only?? it will look killer but a Weiand Stealth will out power it till 4500-5000 rpm!! see what I mean??
Have fun!!
Just me..........................
Thumper
