Anyone use Wilwood Front Drag Race brakes?
they are good brakes, but should really only be used on a drag car. Mainly because the rotor is a thin non-vented unit, it would warp and heat-soak with repeated moderate-heavy stopping. You could probably option that kit with a thicker vented rotor and be ok.
Wilwood's street kit without slotted/drilled rotors is $547. As 302 coupe said, these are thin drag rotors, I think I'd go with a street kit. I'm partial to the RC132 kit, at $350, you can't even hardly beat the price with a Granada swap (unless the granada donor car just had a brake job :D then your just lucky)
HTH
--Kyle
