Anyone using an aftermarket overflow tank?
Mrgreen94gt
SIMMA DA NA!!!
448
West TN
My stock one is leaking pretty badly, and I suppose there's no good reason to get another stocker if something nicer is out there. I've been looking at the Canton one since it accepts the sensor, but its $120.
Anyone have any ideas?
Yeah, thanks to Snoozer I am running the overflow to the washer fluid tank like him.
Looks a lot cleaner :nice:
I'm trying to avoid that route, since I do use my washer fluid occasionally. If I can figure out how to mount it and properly hide away that sensor plug, I may try using one of those hot rod style catch cans.
BTW-I didn't think your engine bay could get any cleaner! :D :nice:
I have a overflow from an old Toyota truck from a junkyard. I stuffed it in my fender in front of the drivers side wheel next to the horns. it works great, and thats all that matters, and you can't even see it....I have a fox, but you should still be able to do the same....
I considering mounting one of the aluminum ones from Summit in one of two places. Either in the fenderwell or in front of the radiator support, in the vicinity of my trans-cooler.
awesome... I am glad my little idea could be put to use for someone else.
I initially did this for easier access to belts now and in the future when i will probably havd a T trim :D
