  • SN95 4.6L Mustang Tech
Anyone using Autometer temp gauge???
  • Thread starter Thread starter LS2 KLR
  • Start date Start date Mar 18, 2004
LS2 KLR
452
Houston, TX
Mar 18, 2004
  • Mar 18, 2004
I was wondering how you got it to work with the stock sensor/plug? I'd imagine you had to run some sort of T into the intake. Is there any way to just wire the two together without using a T. I thought I could just run the aftermarket gauge without the stocker but the computer doesn't like that too much. Any pics you have would be great!
D
D.K
1,011
MD
Mar 18, 2004
  • Mar 18, 2004
I'm in the same boat as you. The computer doesn't like life without the stock sender, so I'll be using a T to wire both senders in.
8yourZ06
128
  • Mar 18, 2004
if you go into your instrument cluster diagnostic mode and scroll through till you get to "temp" it will tell you the exact cynlinder head temp in degrees celcius..
Satan
47
Charlotte NC
Mar 18, 2004
  • Mar 18, 2004
Hey guys. You can put the sensor in a plug hole on the block located on the driver side, right behind the motor mount. Its pretty much on the underneath of the block, so you will need to have the car on stands or ramps to get to it. Also make sure to drain the radiator or you will take a bath.
OD
323
Calgary, Ab Canada
Apr 3, 2004
  • Apr 3, 2004
will i need an adaptor for this? or can i use the one the kit came with?
Satan
47
Charlotte NC
Apr 3, 2004
  • Apr 3, 2004
I used the one the kit came with. Good luck.
b1gp1mp1n247
159
Pittsbrugh, PA
Apr 3, 2004
  • Apr 3, 2004
you can tap into the thermostat housing and use that instead of tapping into your sender.
Mr Plow
148
Suffolk, Long Island
Apr 12, 2004
  • Apr 12, 2004
I did what Satan did. Works like a charm
OD
323
Calgary, Ab Canada
Apr 12, 2004
  • Apr 12, 2004
ya i found that plug behind the motor mount... didnt bother draining any coolant... had a bit of a bath... but it works!!
thanks!
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Saturday at 9:49 AM
CAMTWO1070
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
A
ECT sensor wires gone?? HELP
  • archer886
  • Oct 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 8, 2025
Mustang5L5
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
