Anyone using Autometer temp gauge???
LS2 KLR
452
Houston, TX
I was wondering how you got it to work with the stock sensor/plug? I'd imagine you had to run some sort of T into the intake. Is there any way to just wire the two together without using a T. I thought I could just run the aftermarket gauge without the stocker but the computer doesn't like that too much. Any pics you have would be great!
Hey guys. You can put the sensor in a plug hole on the block located on the driver side, right behind the motor mount. Its pretty much on the underneath of the block, so you will need to have the car on stands or ramps to get to it. Also make sure to drain the radiator or you will take a bath.
