Mustang70, you are right. What was stated is impossible and well....it just doesn't make any freaking sense. But then again, I had to get my car tuned after my cams because it would only turn left. Boy, you wouldn't believe how long it took to get to the tuners making only left turns
I think this is one of those cases where:
1. Forum member reads information.
2. Forum member sleeps.
3. Forum member reads more information.
4. Forum member does some other stuff.
5. Time passes.
6. While trying to type a coherent message on the forum, all information from #1 and #3 are jumbled.
7. The end result is fux0r3d jibberish
The whole "oil" story starts with Mac 4v headers. Certain board members here and elsewhere bolted Mac headers to their Cobras or engine-swapped GTs and ended up with some oil problems. Some people had scored cylinder walls and the whole nine yards. Some just ended up with a little blow-by. The culprit behind the whole mess is believed to be the sloppy welders that weld the Mac headers. There has been problems with leftover slag in the tubes. Then, the bits and pieces as tiny as they may be, are sucked back into the engine through the EGR valve. They then travel through the intake and into the combustion chamber where they end up being ground into the cylinder walls.
For some reason, this seems to be fairly well confined to 4v LTs and few people have reported problems with the 2v headers. Some people on ModularDepot.com have gone as far as to temporarily block the EGR until all the slag is believed to have had time to dislodge itself and travel out the exhaust. You don't want to do it permanently unless you're a die-hard racer because unlike other emissions equipment, the EGR is harmless when it comes to performance and actually helps with mileage a little.
Why am I typing all this at 2:41am? I checked the board one last time before I went to bed and had to comment on the worst disinformation since the fall of the KGB.
