Anyones Supsension squeek bad?
Timin
207
Houston
I've had the Eibach Pro Kit on the car for almost 2 years now. Now that I have put the stock exhaust back on I realized that there are lots of squeeks from the rear end area. Could this be from worn out shocks/struts? Does anybody elses cars do this? Just curious it only does it usually when I move from a stop, I can hardly hear it at higher speeds.
Karl
It could be a lot of things. Did you leave the isolators out when you installed the springs? Isolators are basically a rubber piece that goes underneath the spring to absorb noise. It could be worn shocks. Take one out and test it to see if it makes any noise. It takes 15min to replace both shocks on my car. Could be gear whine as well. Again, could be many things.
