Late to the party I see, but I wanted to add a few things. My 94 V6 could throw separate transmission codes that are not reported by a check engine light. They are reported by flashing the Overdrive light in the cluster. Those codes can not be read by a standard OBDII code reader; I had to go to a mechanic to have them read.
Of course, this was an OBD II car, I do not know if the OBDI system in the 5.0 cars will do the same.
I remember feeling the same kind of shift in my green GT (which had an AODE). The tranny would up-shift then shift quickly into overdrive somewhere around 35-40mph, at light to moderate acceleration. If you can hit the OD button and feel the tranny downshift, you were in overdrive. Pressing OD again will get an upshift back into OD.
There's a certain 2-3 mph point where the computer will shift you in and out of overdrive. I ran into it once in rush hour traffic, annoying as all heck. I just turned off OD for the rest of the trip. It was a while ago, I don't really remember the details but I do remember it happening.
X2 on no WOT in OD. Overdrive on the AODE's is not a gear, it's a band if I remember right. And it can't handle the torque of the V8 for very long. As that band wears out, the tranny will completely slip out of gear into neutral until you take your foot off the gas. Eventually, you'll lose overdrive entirely.
Of course, this was an OBD II car, I do not know if the OBDI system in the 5.0 cars will do the same.I remember feeling the same kind of shift in my green GT (which had an AODE). The tranny would up-shift then shift quickly into overdrive somewhere around 35-40mph, at light to moderate acceleration. If you can hit the OD button and feel the tranny downshift, you were in overdrive. Pressing OD again will get an upshift back into OD.
