Hey AOD-E folks, I gotta Q ?
So I changed my transmission filter and gasket just this week, so now im noticing drops of transmission oil dropping from the end (end of the pan pointing to the rear).
If I tightened the bolts more than the factory specs required is it possible that I have dented the pan where the bolts go through, and that's the reason im leaking ?
Or is it because, I probably din't put the gasket right (cork type of gasket). Does anyone know where we can get the plastic, or rubber factory gaskets ?
