I put in a new throttle body and am havnig throttle cable problems.
When I push the gas pedal in, it sticks and won't come back. I've been told to lube it up and see how it works but there's one thin I need to fix before doing that:
The gas pedal now sits lower to the floor than it did before the install, and I'm thinking the throttle screw on the TB needs to be adjusted. People said to tighten it up, but that brings the pedal closer. Then I realize that probably 98% of people giving me advice probably have a T5, so I am wondering now if AODs need to be set up differently.
So if you've got an AOD, how is your throttle screw on the TB set?
