AOD REMOVAL????????
  • Thread starter Thread starter Georgie
  • Start date Start date May 24, 2006
Georgie
455
Montreal, Canada
May 24, 2006
  • May 24, 2006
I'm doing my AOD to T5 swap... i did the pedals...now I'm removing the AOD.... the AOD cooler lines....i don't wanna **** things up, cuz when i got the car, the ac was removed. What do the cooler lines go too? and how do i COMPLETELY remove anything to do with the AOD in that matter (cooling..)?
is their a small rad ?
any help would be appreciated
The Shape
2,224
East ARKANSAS Delta
May 24, 2006
  • May 24, 2006
The cooler lines run from the AOD to the drivers side of the radiator.
Georgie
455
Montreal, Canada
May 24, 2006
  • May 24, 2006
is their a small rad connected to those cooler lines??
cuz theirs a small looking rad..about 9 x 6. sitting in front of the rad(between the engin & rad)
Georgie
455
Montreal, Canada
May 24, 2006
  • May 24, 2006
bump
five-o-joe
  • May 25, 2006
If you are not the original owner is it possible that it could be equipped with an aftermarket transmission cooler?
50 Resto has one from Ford Racing that measures 7.25"x11" for $60 that is held on the rad with plastic mounts that are kinda like zip ties.
bill302
2,131
alabama,gadsden
May 25, 2006
  • May 25, 2006
click on link below good info. on aod to t-5 swap.... and follow the lines on that cooler if they lead back and connect to the tranny either via thru radiator cooler or not then you can remove them.. post some pictures....
http://wcfords.com/articles/tech/t5swap/t5swap.html
Georgie
455
Montreal, Canada
May 25, 2006
  • May 25, 2006
thats what im using to do my swap..westcoastfords thek article..ok ima go remove everything
Georgie
455
Montreal, Canada
May 25, 2006
  • May 25, 2006
OK I CHECK IT OUT.. THEIRS TWO LINES COMMING FROM THE AOD TRANNY.. ONE GOES TO THE SMALL RAD...AND THEN TO THE BIG RAD( DRIVERS SIDE) AND RETURNS BACK TO THE SMALL RAD, THEN BACK TO THE TRANNY...I GUESS I SHOULD REMOVE ALL THAT SINCE IM CHANGINF MY RAD TO A FLUIDYN ALUM MANUAL RAD... RIGHT??
Georgie
455
Montreal, Canada
May 25, 2006
  • May 25, 2006
BUMP
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
May 25, 2006
#10
  • May 25, 2006
  • #10
In all of my years on message boards, that may be the best title for a thread ever
When you take it out beat the crap out of it with an axe or sledgehammer
Modular2v
3,222
23
99
oklahoma
May 25, 2006
#11
  • May 25, 2006
  • #11
CORRECT
Georgie
455
Montreal, Canada
May 25, 2006
#12
  • May 25, 2006
  • #12
ok thanx guys...CANT WAIT TO DRIVE STICK!!!!!!!!!!!
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
P
Drivetrain Aod to T5 shifter Question
  • Piratemike
  • Apr 22, 2024
Fox 5.0 Mustang Tech Feb 25, 2025
Piratemike
P
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
