we'll next week im racing my friend in a 90 5 speed 5.0, he has headers, 3.73's, cai, msd, king cobra clutch,x pipe, well me being automatic already puts me at a disadvantage, would doing the aod shuffle help out, or should i just leave it in drive?
nosmatt said:if u know how to drive, and the 3.90 gears are in, and you have tires that do not suck, you should beat him.
of course, you must be honest about if you can drive or not.............. if you cut a 1.2 second light, and nail down a blistering 2.6 60' time, then a hyundai could beat ya![]()
Kdubslugga said:It doesnt matter if you have the shifter in OD or D, the AOD will not shift into overdrive under WOT unless you have a shift kit then it may, which i see you have, just stick it into D to be safe. The only reason to the shuffle is because the stock tranny shifts at 4700-4900rpm, so where does your tranny shift at??? If its close to 5500 your fine to just leave it in D
sgarlic said:But the problem is, if he thinks he's WOT, but is a tad backed off, he'll hit OD, which is why you don't put the shifter in OD unless you're on the highway, period.
