Aod To Fmx Swap?
  • Thread starter Thread starter Nathan Reible
  • Start date Start date Oct 14, 2012
1 of 2 Next Last
N
Nathan Reible
33
  • Oct 14, 2012
I'm running an AOD right now but it's pretty tired. I recently found a rebuilt FMX with the bell housing and converter for $200. Is it worth it and what is required to swap it over?
N
Nathan Reible
33
  • Oct 15, 2012
I just talked to the guy who's selling it. He bought it from the guy who rebuilt it, he said he hasn't put it in his car yet but everything looks good. He decided to go with a C5 instead and has no plans for using it. He wants $160 for everything, I think that's a steal price. I'm not planning on doing a whole lot performance-wise to my Mustang for now so I think it will be fine. I'll just keep my AOD and have it rebuilt later with a TCI Pro kit for future power-adders.
Would swapping it over require any additional parts since it has a vacuum throttle valve? I could probably just run a vacuum hose from my intake to it and call it a day. Is there anything else I would have to do?
88LX5.Oh
1,442
205
94
Arkansas
Oct 15, 2012
  • Oct 15, 2012
FMX is quite possibly the worst transmissions Ford ever made. If I had one I would scrap it out in a heart beat.
AOD > FMX
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Oct 15, 2012
  • Oct 15, 2012
Why on earth would you go from an already weak AOD that was based on an ever weaker FMX? I think they use the same 164 tooth plate and bellhousing. You may need to swap out the yoke on driveshaft and fab up a crossmember, then work out the shift linkage , tv cable. Most people go from the FMX to the AOD or AODE.
ratio411
3,870
73
109
Pensacola FL
Oct 17, 2012
  • Oct 17, 2012
FMX isn't a 'bad' tranny, but it is:
HEAVY! (Cast iron!)
Old... (Designed in the mid-1950s)
Longer than an AOD/C4/T5... (So it will need a custom driveshaft)
Harder/expensive to work on... (NO performance parts available AT ALL.)
and, IIRC, the mount location is not compatible with a C4 family tranny. The tailshaft position for the FMX is between a C4 and C6, which would require custom work on the tranny crossmember.
No wonder the seller doesn't want it.
ratio411
3,870
73
109
Pensacola FL
Oct 17, 2012
  • Oct 17, 2012
Oh, and the FMX uses a kick-down, or so called 'passing gear' linkage.
It is similar in theory to the TV cable on an AOD, but I doubt you would be able to get the cable to work properly.
You can run an FMX without the kick-down in operation, but it will always accellerate like a dog unless you manually shift.
gearheadboy
1,425
177
84
Greencastle Pa
Oct 17, 2012
  • Oct 17, 2012
FMX= cast iron and alot of it. They weigh a ton. They don't work too bad but the thing is a monster.
N
Nathan Reible
33
  • Oct 17, 2012
I decided to just pull my AOD and rebuild it, that way I can keep overdrive. I'll probably buy a TCI pro kit to rebuild it with, get a mild converter (2500-2800) and call it a day. Anyone have suggestions for the converter? A street/strip is all I'll need.
gearheadboy
1,425
177
84
Greencastle Pa
Oct 17, 2012
  • Oct 17, 2012
AOD converters are expensive. I think a TCI one is about the cheapest decent one.
N
Nathan Reible
33
#10
  • Oct 17, 2012
  • #10
Gearheadboy, I see you're running a manual rack and pinion in your Capri, how is it? My rack and pinion has seen better days, I thought about installing a manual flaming river as they're pretty inexpensive ($300).
gearheadboy
1,425
177
84
Greencastle Pa
Oct 17, 2012
#11
  • Oct 17, 2012
  • #11
When I did mine they were crazy. Mine is a new factory Ford unit. I love it. Steering shaft needs changed too, figure that in.
N
Nathan Reible
33
#12
  • Oct 17, 2012
  • #12
Yeah
Yeah I know, TCIs run about $350-$400. B&M makes them too, they run a bit less...TCI is probably what I'll go with though.
N
Nathan Reible
33
#13
  • Oct 17, 2012
  • #13
Is the Ford unit less expensive than the flaming river? How much would I be looking at total?
gearheadboy
1,425
177
84
Greencastle Pa
Oct 17, 2012
#14
  • Oct 17, 2012
  • #14
I bought a NEW Ford one on Ebay. Got lucky. Cheap. Flaming rivers are cheaper now. At least on Ebay. However they may be knock offs but they are cheap.
N
Nathan Reible
33
#15
  • Oct 17, 2012
  • #15
Yeah I just looked at a Flaming River Deluxe installation kit. It comes with the rack and pinion, steering shaft, outer tie rod ends and bushings for $411. I think it would totally be worth it as I plan to take this car to the grave with me (lol).
gearheadboy
1,425
177
84
Greencastle Pa
Oct 17, 2012
#16
  • Oct 17, 2012
  • #16
Ya thats not bad. Are you sure you want to delete P/S on a street car?
N
Nathan Reible
33
#17
  • Oct 17, 2012
  • #17
I had a 90 LX hatchback some time ago with manual steering...it wasn't that bad. Plus my wife would be less likely to ask me to drive it (lol).
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 18, 2012
#18
  • Oct 18, 2012
  • #18
Unless you are modifiying the engine to move the powerband up a few thousnd RPM, use the stock converter. A looser converter allows more slippage at low RPMs to allow the engine to get up into the RPM range where it starts to pull hard. With a stock engine you run out of power above 5200 RPM, so you want it to engage soon. That way, you don't waste the best part of the engine's power RPM range, the part where it pulls the hardest.
Reactions: 88LX5.Oh
N
Nathan Reible
33
#19
  • Oct 18, 2012
  • #19
My motor has an aftermarket cam, the few times I've driven it it doesn't do very well until about 2500 rpms or so. Anything under that doesn't produce much power at all.
ratio411
3,870
73
109
Pensacola FL
Oct 21, 2012
#20
  • Oct 21, 2012
  • #20
Well, then you certainly need a loose stall converter.
What rear gears are you running?
That is your next issue if you are dealing with a cam that needs to spin up quickly to make power.
The stall will help, but if your gears are too high (low number), you can even operate out of your stall's range and burn up your tranny from the heat.
1 of 2 Next Last
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
A
Drivetrain 91 AOD linkage at transmission
  • alchemist1
  • Sep 29, 2025
Fox 5.0 Mustang Tech Sep 29, 2025
JD1964
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
