My 02 is having a really weird tranny problem, which I will try to describe.
Starting off easy from a stop light, I will accelerate to about 35-40. When I get to around 40, and the tranny shifts up to a higher gear, the tranny will start to shutter shake and vibrate (the whole car) as it goes into gear. While driving at that speed, if I want to accelerate and give it a little gas, it will do the same thing only worse - more shakes and vibration as it drops into a lower gear. It seems to do it worse when the tranny has warmed up. It will also do it on the highway at passing speeds. As the transmission is going into the highest gear, it will do it. It does it on the last shift of an acceleration as it goes into the cruising gear.
It just started doing this about a month or two ago. At first it was only doing it every now and then, now it does it all the time, and its getting worse. Automatic 02 GT vert. 42k on the clock. Car runs perfect otherwise.
Can anyone please shed some light on this.
