AOD TV cable adjustment
SamSnyder
196
OK, swapping a different AOD into my '90 5.0 and have seen warnings that the TV must be re-adjusted to avoid burning up my new unit, and just wanted to be sure: Is it merely a matter of zeroing the TV setting at the throttle body to match the new trans at its base setting? That is, is it simply a matter of releasing the locking mechanism on the TV cable at the throttle body, letting both the throttle valve and the TV lever on the side of the trans return to their natural state, and then re-locking the mechanism on the cable at the throttle body?
Modular2v said:
there is actually a preasure guage that u have to hook up to the tranny to get the right preasure.....should be 35lbs of preasure.....tv cables are ridiculous!!!!
what was said above. Don't mess around with this, if you don't set it with the pressure guage you can expect a shortenend life for your new tranny......
I've always adjusted my AOD's following certian rules, and never had any problems. It was actually one of the best shifting trannys I've driven, and lasted me years with lots of abuse, untill I sold the car.
To properly adjust the TV cable, pop the TV cable out of the throttle body gromet, remove the metal clip that locks the plastic slide to the shaft of the TV cable. Now, with the slide freely moving, have a friend mash down the gas pedal and hold it, car off of course. With the pedal down, pop the TV cable back into the gromet on the throttle body. The plastic slide should still move freely at this point to attach. Now insert the metal clip back into the slide to lock it down, have you friend release the gas pedal, and you are done.
Of course there is a pressure gauge that tranny shops will use to dial in exact line pressure via the TV cable, but I've been told by many people including a tranny builder that the way I just described will work fine.
So are you guys meaning pull all the slack out of the black slide it sets on or the piece with the spring please help been trying to get this right for weeks now...
