  • 1994 - 1995 Specific Tech
aode is giving me.....
  • Thread starter Thread starter davins130
  • Start date Start date Apr 11, 2005
davins130
424
  • Apr 11, 2005
last winter my tranny did this thing where when i first drive it when it was real cold out, it wouldnt shift out of first gear for about 10 seconds, it would just keep revving, and then finaly slam into 2nd.... it went away with the warm weather, but since last week it does it to me all the time, and its been like 75 out every day..it doesnt suprise me because ive been beating the hell out of with with my nitrous, and it doesnt bother me because as soon as it dies im swapping it for a tko 3550, but any ideas on what it might be?
M
_MATiC
140
El Paso, TX
Apr 11, 2005
  • Apr 11, 2005
check your modulator. mine does the exact same thing, as does my dad's truck, and my girlfriend's honda. mine isn't as severe tho and usually doesn't happen if i let my car warm up when it's coldd.
davins130
424
  • Apr 11, 2005
whats my modulator?
M
_MATiC
140
El Paso, TX
Apr 11, 2005
  • Apr 11, 2005
its kinda long to explain..go here http://auto.howstuffworks.com/automatic-transmission16.htm
that explains what it does
davins130
424
  • Apr 12, 2005
do you know where this thing is so i can replace it?
mustangsammym
44
Georgetown Texas
Apr 12, 2005
  • Apr 12, 2005
Modulator
The AODE does not have a modulator so don't waste your time looking up on it.
If you don't know about these things don't post ignorant answers.
SilverFoxbody
149
  • Apr 12, 2005
True....that is the dumbest thing I have heard yet - modulator on AODE HAHA! People will confuse on AOD, but not on AODE......
your problem is sticky valve body and governor. Take the driveshaft down, and pull the tail housing - in there will be a rotating mass called the governor - take it apert and clean it where it moves FEELY in it's bore. Now drop the pan and take the VB down - clean it with carb cleaner (the best) until it is immaculant - bolt it all up, addf luid - done deal!
davins130
424
  • Apr 12, 2005
smart guys to the rescue! damn that sounds easy enough, maybe i'll just throw in a shift kit while im in there, and im sure i need a tranny flush anyways i dont think its ever had 1 and its at about 93k thanks
davins130
424
  • Apr 12, 2005
shift kits arent that complicated to install are they?
AznStanger3v
2,026
Northern VA
Apr 12, 2005
#10
  • Apr 12, 2005
  • #10
good to see you guys are so warm and loving towards people that make mistakes
davins130
424
#11
  • Apr 12, 2005
  • #11
im glad they said something or else i'd be looking for a part that i dont have
davins130
424
#12
  • Apr 12, 2005
  • #12
...........unless the're both wrong too....
KingDiamond
637
Chicago, IL
Apr 12, 2005
#13
  • Apr 12, 2005
  • #13
I wouldn't bother, this is a sign from above... do the TKO swap now!
bjl95mustang
1,495
Austin,TX
Apr 13, 2005
#14
  • Apr 13, 2005
  • #14
It could be a number of things, mlps, worn seals, burnt clutches, ect. I would just start on planing the swap. A stock aode isnt made to handel that much power. Now one that is built is another story.
davins130
424
#15
  • Apr 13, 2005
  • #15
i know i know, i just thought if it was easy fix then i could just get it shifting right and not spend the money on a tko now, but o whell tko here i come... Is there an entire kit for a aode to tko3550 swap? i know ive seen brand new swap kits before, and also is there anything aftermarket i should install while i put in the 5 speed?
KingDiamond
637
Chicago, IL
Apr 13, 2005
#16
  • Apr 13, 2005
  • #16
TKO and 3550 are two different transmissions
I think D&D performance can set you up with an entire kit
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
