The below is quoted from oinkaodeoink.
Has anyone with an automatic ever entered any of these settings?
--AODE Settings--
:Scalers:
trans tv adder 1-2 =16 ( Trans TV adder, is an adder to the trans presure)
1-2 time=0 ( time delay between shifts)
tv adder 2-3=16
2-3 time=0
tv adder 3-4=20
time 3-4=1 (Lower this value to make the 3-4 shift quicker. Units i believe are in seconds)
-- WOT shift points--
:Scalers:
take note, the actual 1-2 shift is going to be around 1000rpms off, from the setting you enter. The 2-3 shift is around 500rpms off from the set WOT shift point. So if u want the actual 1-2 WOT shift to happen at 5900 rpms, you would enter 4900rpms for the 1-2 WOT shift, and so on. This is dependant on which gears you are running.. SO the higher the gear( 410's-up) might require an even more drastic change.
--Setting the tranny to shift firmer--
:Functions:
( entering higher numbers on the Y axis (Y axis=MPH) at each throttle position(X axis=TP) will firm up the shift at that TP) ( these values might differ depending on which gears you have)
trans tv press 1-2= x 0 0 0 0 0 52 400 600 1020
y 5 5 5 5 5 10 17 46 56
trans tv prss 2-3= x 0 0 0 28 52 252 400 600 1020
y -5 -5 -5 -5 0 8 8 27 42
