  • 1994 - 1995 Specific Tech
aode to t-5 swap
  • Thread starter Thread starter 94GTMOOSE
  • Start date Start date Jun 28, 2005
94GTMOOSE
303
jersey shore
Jun 28, 2005
  • Jun 28, 2005
soon i will doing the swap to the t-5 from the slush box thats in there now.
i have a basic parts list, but maybe you guys could fill in some gaps.
T-5 94-95
94-95 bellhousing
clutch fork
clutch
clutch cable and quadrant
94-95 pedals
94-95 flywheel
Is there anything i am missing
LethalInjection
217
Arkansas
Jun 28, 2005
  • Jun 28, 2005
I got the manual tranny computer when I swapped...
94GTMOOSE
303
jersey shore
Jun 28, 2005
  • Jun 28, 2005
do i really need the computer too. Some say yes some say no, but if its a installer option i think i will stick with the aode comp.
Someone once told me that the aod comps have a better tq curve, so they would be less sluggish. is that true or is this bull crap.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Jun 28, 2005
  • Jun 28, 2005
the t4m0 is not necessary, but using the aode eec will cause driveability issues. the aode tranny pulls timing between shifts which will cause you to run rich when the eec is trying to shift the transmission that isnt there causing sputtering and a rough driving car. the car will run and drive with the automatic eec, but i would consider the 5spd eec a necessity if you want a car that runs properly. here is a list of what i needed when i did my swap.
t5 transmission
bellhousing
clutch fork
throwout bearing
pilot bearing
pedal assembly
clutch cable
flywheel
clutch assembly
shifter
manual transmission harness
5spd eec
that is all that comes to mind off the top of my head. if i remember anything else, i will post it up. if you need any help with the swap process itself, let me know since i went through it already.
SorsCode
20+ Year Stangneter
Jun 10, 2003
1,024
434
113
St. Louis, MO
Jun 28, 2005
  • Jun 28, 2005
What he said about the computer is 100% true..
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
