AODE to TR-3650 swap advice needed
RECNIZ
I've got a 2000 GT and I'd like to swap out the AODE and replace it with a TR-3650 which I already have "just the transmission". Can somebody kindly give me a list of parts needed to do the swap. Thanks
Here is the list I am using for the same swap...
Trannsmission
Clutch
Pressure Plate
Flywheel
Throwout bearing
Pilot bearing
Clutch fork
Clutch cable
Clutch pedal assembly
Manual trans wiring harness
Driveshaft from auto will work but you need the input yoke from a stick.
Shifter
Lower rubber shift boot
Interior shift boot and bezel from manual
Bellhousing bolts
Drive shaft bolts
Flywheel bolts for 5 speed
Pressure plate bolts
shifter handle bolts
shifter bolts
Car will drive wihtout the manual computer, and all auto computer functions can be "turned off" with the use of an aftermarket chip.
