Are 3rd gen injectors better???
So, I'm about to install an Explorer intake on my 91 LX. But, I also bought these 3G fuel injectors. I guess they're off 93-95 5.0 Mustang. I was told they have a better/more efficient spray pattern, optimizing power and better mpg than my 91 injectors. Surprisingly, I have searched and haven't found much talk about these.
Is it worth swapping? Does anybody know much about these compared to my 91's?
Here's a pic
those are called ev6 injectors, 86-93 used ev1, the spray pattern is different ( 4 hole vs single) there are 2 different electrical connectors called uscar & jetronic for these inj. just make sure u get the right one, i just bought 24# inj ford racing part# m-9593-aa302, these will have the right elec connection ( jetronic) to be used with the 86-93 mustang
The fat injectors from the '91 have a single pintle; the one you have in the pic is from the Explorers and newer Fords (EV1) and they have Four pintles, so they atomize the fuel better. I'm using the Explorer style and they're 19# just like the Mustang, so if you have all eight go ahead and use them, they plug right in without modification.
The newer EV6 injectors look almost identical to the skinny EV1 injectors except they have a more rounded elec. connector, and they dont fit without adapters for the connectors.
