Basically the title is the question, but thats what I have and thats what I heard. Does anyone else agree? Thanks.
You guys with centrifugal blowers and 4.10's, can you hook in 1st and 2nd gear?
I think with a better set of DRs 99.9% of my traction problems will go away. I have Nitto DRs and I’m picking up some MTs this spring.You guys with centrifugal blowers and 4.10's, can you hook in 1st and 2nd gear?
well i have nitto drags, so take that into consideration when i say this, if i had some better drag radials on it'd do better.....
if it's cold out & if sitting at a light & decide i want to go balls out, forget about it. i won't catch traction till the top of 3rd, sometimes 4th gear
if it's warm out i can launch at 3k on the street play with the clutch a little bit & it'll grab. on occasion it'll start to break loose at 5k-5500 from boost in 1st gear. but, after that i'm good to go.
now if i do a lil burnout & get the tires warm, i'm usually good to go
also, keep in mind i have full suspension setup for drag, so it's set up to hook
What are you using for the quad shocks and pumpkin control arms? I am getting ready to start setting up my rear-end for the strip as well and I would like to see what you guys on here are using that works well.
I am going to put on an adjustable torque arm as well to turn the pinion angle down and provide better weight transfer.
I just had 4.30's installed in my 03 cobra. With the factory eaton s/c, 1st, 2nd, and 3rd are pretty well useless. I installed these because I am laying the foundation for my twin turbo kit which I hope to get in the next couple months. My tuner says the twin turbo kit will hit full boost at 4-4500 RPM. The 4.30's are just to help it get in the RPM range a little faster. They may prove to be little too steep. Only time will tell.
that must be a handfulI just had 4.30's installed in my 03 cobra. With the factory eaton s/c, 1st, 2nd, and 3rd are pretty well useless. I installed these because I am laying the foundation for my twin turbo kit which I hope to get in the next couple months. My tuner says the twin turbo kit will hit full boost at 4-4500 RPM. The 4.30's are just to help it get in the RPM range a little faster. They may prove to be little too steep. Only time will tell.
