Are all 5.0 smog delete pulleys the same?
pleasehelp
686
Poplar Grove, Il
I've been shopping around for smog delte pulleys and keep seeing 87-93 ones then 87-95 ones but they look the same. I know that the accesories on the fox mustangs sit a little further away from the engine than the sn95 mustangs do so I don't know if this would be a difference or not. Are there different pulleys sizes? Thanks for any info.
Blackgtmustang said:
why do you need a smog delete pulley for... the reason to get rid of it is to have a one less pulley so just buy a shorter belt...
:stupid: Just take the actual pump off and all of thoes lines connected to it and run a 895k6 short belt.
pleasehelp said:
Reason why I wanted one is cause I've read that the people that ran the short belt had problems with it coming loose and falling off. So I wanted to avoid this and just get the delete pulley. :shrug:
I've never had that problem. Personally, I think smog and a/c delete pullies are a ripoff. They're selling you something that isn't needed. Just reroute the belt to bypass all that crap.
