Are all K-Members created equal?
poindexternasty
148
Hey all,
I hit a curb a little while ago and suspect I may have bent my K-Member. I am replacing the A-Arms w/ cobra control arms and am searching for a new K-Member should I need to swap it out.
My question is this:
Are all K-members created equal? You can tell me how GREAT they are but how about how BAD one is? Has anyone ever had a K-Member take a dump on them NOT from hitting something or breaking it yourself?
I am considering this unit from Summit:
QA1 Precision Products MU2TK - QA1 Mustang K-Members - summitracing.com
A LOT cheaper than a $699 MM unit.
Thanks!
I have always had great luck with UPR stuff. I had the k member, control arms, coil over kit, bumpsteer kit, and 4 bolt c/c plates from them. I loved them and for the price I couldn't go wrong, especially being chrome molly. Installation was a breeze and the customer service was outstanding. The only thing is, I would save up for a better coil over set up. The UPR is ok, but you rase and lower the spring by hand and lock it in place with a set screw. I like using the nuts and a spanner wrench better myself (personal prefference). As far as the other brands, I don't think you would have a problem with any of them...just stay away from ANYTHING with the name Granatelli on it.
You can use the stock control arms on the UPR K Memeber.
Only if you create your own spring locator for the top of the frame. Otherwise there is no perch for the spring to sit in.
I won't get into the back and forth bashing about K-members but I had a UPR setup on my 2000 for about 3 years worth of daily driving/racing. During that time I had two seperate incidences where I hit pot holes. One of those times the A arm hit the pavement and the only damage was scratches in the powder coating and another time the support for the A arm hit the ground and again just scratched the coating. I was pretty impressed how it held up to that kind of abuse.
Bill
Why do you think your k member is bent? The bolt holes in the k member are oval so it will slide out of alingment sometimes. If you talk to a body shop they will tell you that you will bend your front subframe before you bend the k-member. I had that problem and it made my passenger side wheel sit a little farther back in the fender.
