Are fox heaters really this bad?
  • Thread starter Thread starter lancec2c30
  • Start date Start date Dec 8, 2009
lancec2c30
570
Washington
Dec 8, 2009
  • Dec 8, 2009
I was going to drive my coupe this morning, but with it being 12 degrees outside. I was hoping the heater would work.
I got the car out on the road yesterday. Now today, I let it idle for a good 15 minutes and the temp gauge came up, but the inside of the car was still not heating up at all?
This can't be normal, would the heatercore be plugged up or something?
G
GreenDragon
  • Dec 8, 2009
I had this when I first got my gt back in 1998. The issue was a leak in the water pump caused the fluid level to be below the level of the core, so no heated water was circulating through the core. First thing to check is the level of the coolant in your radiator. My guess is it's low.
G
GreenDragon
  • Dec 8, 2009
Second thing I'd check is if the heater core has been bypassed by a previous owner. If so, you should see two connectors poking through the firewall on the passenger side. Third thing is to see if your ventilation controls are working, allowing you to adjust the air to come into the dash. If you have a broken/cracked vaccuum line, then your vents may be in the default closed position, so no matter how hot the core, no heated air is being pushed into the interior.
stykthyn
5,232
2,652
223
gainesville
Dec 8, 2009
  • Dec 8, 2009
heater core could be plugged, but first I would check your thermostat, if it is failing it will not allow heated fluid to the core, I would also check the fluid level and make sure that it is indeed under pressure. if you have a leak somewhere or your cap is loose the liquid will not be able to absorb as much heat as they should.
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Dec 8, 2009
  • Dec 8, 2009
mine was blowing lukewarm heat for the longest time and its just now starting to get really COLD. so i swapped in a new 192 thermostat, and she heats up like a champ now
T
time only
461
Miami,FL
Dec 8, 2009
  • Dec 8, 2009
Hope you don't have a 160 thermostat in there.
2000xp8
SN Certified Technician
Aug 8, 2003
8,058
1,643
194
NJ
Dec 8, 2009
  • Dec 8, 2009
Ya, that was my thought.
tannerc91gt
2,967
234
Indiana
Dec 8, 2009
  • Dec 8, 2009
160 is definitly not winter friendly
BlackGT89
774
Huntsville, AL
Dec 8, 2009
  • Dec 8, 2009
Yeah, I think these heaters are really that bad, and the thermostats don't seem to last anytime. I've found that treating the heater core to a dose of CLR and replacing the thermostat is pretty much a yearly thing if I want heat. Brrrrr...
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Dec 8, 2009
#10
  • Dec 8, 2009
  • #10
the heat in mine sucked more then a **** star... biggest reason its gone now
krazedstang
670
278
104
Streamwood
Dec 8, 2009
#11
  • Dec 8, 2009
  • #11
i live in Chicago and we get every season here and everything in between, and my heat cranks like you would believe. i was always taught in school that thermostats don't go bad as much as you would think, a 180 t-stat is plenty, that means it starts opening up at 180 and isn't fully opened until about 190. and thats plenty warm
SVTFreak
106
Dec 8, 2009
#12
  • Dec 8, 2009
  • #12
Mine doesn't blow very warm Either. Granted I can almost live without in south Louisiana but I'm a cold natured one. Glad to see about the thermostat thing. Never thought of that. I know the core isn't bypassed and I'll check level after reading this.
A friend told me that a bunch of cars left te factory without some kinda switch installed. Anyone know anything about that?
stykthyn
5,232
2,652
223
gainesville
Dec 9, 2009
#13
  • Dec 9, 2009
  • #13
a 160* thermostat has no place being in a mustang period
lancec2c30
570
Washington
Dec 9, 2009
#14
  • Dec 9, 2009
  • #14
Thanks for the help guys.
We never have temps this cold here. So my coolant was actually starting to slush ever so slightly. I went to down and grabbed a jug of antifreeze and swapped in half of it.
I still need to check the thermostat, for all I know it could be the original, and have 180k on it.
R
rwood126
161
mCdONOUGH, GA.
Dec 9, 2009
#15
  • Dec 9, 2009
  • #15
Mine went out 2 weeks ago...I have small heater that plugs in to the cig. lighter socket. Yeah...it sux!!
srtthis
5,129
1,666
204
Maryland
Dec 10, 2009
#16
  • Dec 10, 2009
  • #16
haha i had an issue with my lightning for 1 winter that heat didnt work. keep popping fuses for some reason.. it SUCKED! the stang is just a weekend toy. so i could care less if it has heat or ac.
T
THOR74
72
Ontario, Canada
Dec 10, 2009
#17
  • Dec 10, 2009
  • #17
I don't drive my car in the winters, but in the late fall it gets fairly cold up here and when I have had occasion to use the heater it turned the cabin into a sauna in short order.
As far as I've known, the stock heating system works great - but the V8 has to warm up first and that can sometimes take a bit longer than smaller engines and when not actually being driven shortly after start up.
I generally agree with all the other advice given here.
beyondspexj
265
Las Vegas
Dec 10, 2009
#18
  • Dec 10, 2009
  • #18
ill have to try that CLR. mine was bypassed when i bought it. no clue if the core is bad or if they were bypassing whatever they could since the egr is gone and smog pump equipment has been disconnected. think im just going to run hoses back to it and find out if it leaks or if its just clogged before pulling it out and/or replacing it.
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
G
2016 GT, Cold Air/Tune Trouble (overheating) . Advice/Help Please!
  • GLStang
  • Sep 6, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2025
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
