Are The Older 4.6Ls Really That Bad?
  • Thread starter Thread starter GT Drifter
  • Start date Start date Jul 7, 2007
GT Drifter
386
Ontario, Canada
Jul 7, 2007
  • Jul 7, 2007
I always hear that the older (first) 4.6L Mustangs aren't really all that great. Not much power and not a great design. Now I dunno if this is true. All I know is 5.0Ls.
How are the 96-98 4.6Ls? Are they as bad as I hear?
I believe they had Traction Control too right? Possible to DD them 24/7 365/year?
black_96_GT
35
Jacksonville, Fl
Jul 7, 2007
  • Jul 7, 2007
They made less power then the 99+ GTs because of the head and intake design. The good news is you can put the 99+ (pi) heads and intake on a 96-98 and make the same power. If you read any mustang mags 5.0 mustangs and superfords just did an article about those engines. They make good power with a pi swap and are pretty reliable. I don't think any had traction control (mine doesn't).
CobraRed_96_GT
1,421
UCSD/La Jolla
Jul 7, 2007
  • Jul 7, 2007
don't forget PI cams too. Theres nothing wrong with these cars besides not having as much power as a PI car. Yet if you change out NPI parts w/ all PI parts (which can be done for cheap cuz stock gt parts are everywhere) you actually get more power w/ a 96-98 cuz you bump the compression up a bit. Besides that there is no traction control, but i've driven a 2001 a lot and find myself turning it off a lot, lol. Other than this, the cars are basically the same except for the 96-98 having the T-45 manual which by poll most likely is found to be better overall than the TR-3650 which is pretty weak, tho the T-45 does have a 2.97 first gear.
san~man
O-G
A little grass shack on a big lava rock
Jul 7, 2007
  • Jul 7, 2007
You can do the PI cams and intake, and you'll be close to a PI car in terms of HP.
Out of the 3 (PI heads, cams, or intake), the heads produce the least bang for the buck, and require the most labor.
Superhereaux
chicks make me feel inadequate
538
South Texas
Jul 7, 2007
  • Jul 7, 2007
'96 to mid 'o1 have the T-45, and who said the 3650 was weaker?
early 3650's are notchy and don't shift too smoothly but i've never heard anyone say they're weak, in fact quite the opposite
stangbanger01gt
26
  • Jul 7, 2007
That's what I was thinking too. As far as 96-98's go, I think they're great looking cars, though they don't have a ton of power stock; but they are reliable daily drivers and can still be modded like any other mustang (though you'll have to put more time and money to make it run with later models and hot 5.0's)
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jul 7, 2007
  • Jul 7, 2007
I like mine...still a little weak compared to others but with a more aggressive tune and a few more mods I could break 12's I'm sure.
Mustang5L5
Mod Dude
Feb 18, 2001
43,313
18,028
224
Massachusetts
Jul 7, 2007
  • Jul 7, 2007
They don't have TC.
Traction control started in 1999 with the PI 4.6Ls
four six
506
Hobart, IN
Jul 7, 2007
  • Jul 7, 2007
96-98 Gts are plenty good. They are just so damn sexy
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 7, 2007
#10
  • Jul 7, 2007
  • #10
The non-performance improved 4.6 is not as powerful as was mentioned but as long as the intake manifold has been updated it is just as reliable as any 4.6 engine out there.
CobraRed_96_GT
1,421
UCSD/La Jolla
Jul 7, 2007
#11
  • Jul 7, 2007
  • #11
Superhereaux said:
'who said the 3650 was weaker?
This was on the first two pages of searching for "TR-3650" Dont know what lead me to think a t-45 is better
SaleenGT2001 said:
broken 3650 at 19K (overshift at the track), rubuilt in dec 05
svtpower said:
One more good thing about the 99s is they still had the trusty T45 transmission. I think the TR3650 used in later years is a total POS.
Thread title: Help quieting the 3650
65fastback2+2 said:
Its like driving around with a clothes dryer of marbles at my side....when you can hear it over the radio and exhaust...you know its gonna be annoying...
any of you guys had any luck quieting em down?
amc75 said:
when im in 5th gear going between 50-65 mph, i notice a noise coming from the shifter console/gearbox. the noise is hard to describe..kinda like a grinding sound. anyone know what that might be? thanks.
myponyrocks said:
normal if its a 3650 any way
triggz said:
01 GT 3650 transmission loses 2nd gear, total transmission overhaul at 60k.
boatillo said:
Has anyone here sued, or do you know someone who has sued Ford Motor Co. and/or Tremec about the very annoying 1-2 and/or 2-3 clunk in the TR3650?
There is a 1,700+ postcount thread on this site with owners who experience this, and a TSB released by Ford that usually fixes the issue. This TSB costs a minimum of $1,646.57 for those whose warranties have expired. I believe this issue warrants a Recall status, and the law should prove disgruntled owners right.
(I own a 2003 Mach 1, with 4100 miles on the odometer and I have fallen out of the 3/36 warranty period. I should not have to pay for a psuedo-recall.)
SaleenGT2001 said:
you're crazy!!
a T56 would be the best upgrade he could do. the 3650 is a weak POS! i wouldnt waste the money on another.
BurningRubber said:
If it wont go into gear and grinds any time you shift its a 3650...
Mustang5L5 said:
3650 is also clunky like a mofo...especially when cold.
I hope you got a later 03/04 3650 as the 01/02's were especially bad. Even my '03 gets a bit clunky into 2nd when the temp gets under 50 degrees
Mustang5L5
Mod Dude
Feb 18, 2001
43,313
18,028
224
Massachusetts
Jul 7, 2007
#12
  • Jul 7, 2007
  • #12
In the 3650's defense, it is rated at 360 ft-lbs, which is technically stronger than a t-45 and the base 3550's.....but like i said in the above post...they shift like garbage.
But still, knowing what i know, if you gave me the option of either a t-45 or a t-3650 when i bought my car, i'd still take the 3650.
CobraRed_96_GT
1,421
UCSD/La Jolla
Jul 7, 2007
#13
  • Jul 7, 2007
  • #13
this is true
gtstangau
133
Alabama
Jul 7, 2007
#14
  • Jul 7, 2007
  • #14
Hmm...last time I checked shifting was fairly important!
four six
506
Hobart, IN
Jul 8, 2007
#15
  • Jul 8, 2007
  • #15
Maybe its because I have a rebuilt one but mine is smooth
helty
some Ukrainian's enjoying a handjob via my credit
Mar 30, 2005
1,461
Baltimore, MD
Jul 8, 2007
#16
  • Jul 8, 2007
  • #16
You guys make it out like the 3650 is made of glass.
All Hail the T-45
Big block
#17
  • Jul 8, 2007
  • #17
Was the 94 GT the last year of the 5.0, and didn't have like 10 less horsepower than the 96-98 4.6?
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Jul 8, 2007
#18
  • Jul 8, 2007
  • #18
well im glad i have a t45, tried and true i think the T5/T45 is a great transmission
Mustang5L5
Mod Dude
Feb 18, 2001
43,313
18,028
224
Massachusetts
Jul 8, 2007
#19
  • Jul 8, 2007
  • #19
95 was the last year. They were rated at 215HP
thr 96-97 4.6L were also rated at 215, while the 1998 was 225HP
The 5,0 however, has a little more low end torque than the 4.6L.
Twista
510
@ the z00 in chicago
Jul 8, 2007
#20
  • Jul 8, 2007
  • #20
the first gen 4.6 just carries the 5.0's exhaust sound (meaning a v8 sound and not the v6 piny sound). Its slow, but it keeps the v8 tone. Sometimes i think a stock 96-98 v6 could beat my car since the o/r pipe rob'd me =]
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
