ATF in engine?
  • Thread starter Thread starter CarFreakGT
  • Start date Start date Sep 5, 2010
CarFreakGT
20+ Year Stangneter
May 26, 2003
395
11
29
Louisville, KY
Sep 5, 2010
  • Sep 5, 2010
I've been told by two people this week that an 'old school' tech to clean out sludge is to pour ATF in your engine, run it for a few minutes, then drain and replace the oil. They also said that you have to drop the oil pan to sufficiently get all the sludge out, then re-install it. Is this common? Safe?
Granted, I'm a novice w/ cars. But, I've been around several guys for years who work on cars a lot more than me, and I've not heard of this.
2+2GT
3,333
10
79
Southeastern Pennsylvania
Sep 5, 2010
  • Sep 5, 2010
There are products on the market specifically made for flushing the crankcase. I have used Gunk™ for decades. When I pull the valve covers to adjust the valves, the heads are clean.
woodsnake
1,352
15
69
Hicksville, NY
Sep 5, 2010
  • Sep 5, 2010
I've used ATF before with good results, but the results will depend as much on what kind of oil you use. The worst case I've ever seen was a friend of mines car years ago. He only used quaker state, and we had a reason to pull his valve cover off one day. I've NEVER seen so much crap on an engine in all my life! It was literally a 'frozen' waste land. Solid 'oil' all around the springs, with only enough clearance for the springs to move. It was amazing to me to see. If you use good oil, and change it fairly often, you shouldn't have any sludge anyway...
rbohm
6,698
550
204
tucson,az
Sep 5, 2010
  • Sep 5, 2010
atf does work, so does diesel fuel. just remember to use a qt of regular engine oil at the same time for lubrication. you can also use marvel mystery oil as well. run the engine for 20 minutes at idle, then change the oil and filter.
mudbilly
175
South County, Maryland
Sep 5, 2010
  • Sep 5, 2010
be careful..........i bought a '68 f150 and one of the first things i did was change out the oil,,,,,what i din;t know was that previous owner didn't use detergent oil.................
next thing i know, the oil pump is clogged with crud, and i'm pulling the engine .............
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Sep 6, 2010
  • Sep 6, 2010
I'd do it on a motor that is gummed up. However, I would pour in 1qt and drive for about 100miles before a filter and fluid change. Doubt you'll have to drop the pan, it's not a miracle just oil with more detergent in it.
Realmongo
I prefer to be called "Evil Genius"
2,468
86
99
Western Mass
Sep 6, 2010
  • Sep 6, 2010
That was an old trick that started back in the 1950s. You would add a quart of GM Type A ATF in place of 1 quart of oil at oil and filter change time to severely gunked-up engines because the ATF had a detergent additive (this was back in the days of non-detergent motor oils). Today you have good oils and a selection of high-detergent additives to select from.
Eastern North Carolina Autocross Events!
  • Warhorse Racing
  • Feb 23, 2026
  • Regional Forums and Event Information
Regional Forums and Event Information Feb 23, 2026
Warhorse Racing
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
