auto to five speed help!
tuner4life
What all is needed to completly swap my auto from my 94 gt to a 5spd?? like what parts? is there a kit? where to find it if there is? and what tranny?? Please help me out guys.. thx
i believe mustang specialties sells a kit.
You'll need transmission, I used a tremec so had fox bell housing, dust shield, 5/8" spacer from steeda, clutch fork, clutch, pilot bearing, throwout bearing, trans. harness, t4m0 computer, pedal assembly. i think that is it if i remember correctly.
You can find all your parts from a donor car if your local parts yard has one. You need the tranny, bellhousing, tranny mount, shifter, clutch fork, trans harness, computer, pedal assembly, clutch cable, dust shield, fly wheel, 5 spd shifter bezel for the console, the rubber boot that's located under the console, and a new clutch setup with bearings.
I think that's it??
t5 from a 1994 or 1995,t4mo computer,manual driveshaft,bellhousing from 94,95 mustang,pedals ,clutch cable, flywheel, pressure plate, throw out bearing, pilot bearing,shifter,clutch, i think thats it i got most of my stuff on ebay. i got the clutch kit from jegs flywheel and clutch cable & quadrant from summit
The driveshaft from your auto tranny will work, you don't need to replace it. I didn't have to swap it.
