Auto to manual swap
I'm about to do a 4r70w to T3650 swap. I have assembled a pretty complete kit:
-FRPP Aluminum driveshaft with correct yoke
-RAM HDX clutch kit (ford pilot bearing)
-OEM clutch fork kit
-Clutch cable, firewall adjuster, quadrant
-OEM Cobra manual pedal box
-SPEC Aluminum flywheel and hardware
-Ford factory remanufactured T3650 (all TSBs completed)
-Lower shift boot / plate
-MGW Shifter, upper shift boot and gasket (no silicone required)
-Leather shift boot
-FRPP Shift knob
I have read comments by people selling the ECU harness that the 5 speed and manual harnesses are the same. Anyone know if this is true?
Also, I have an ECU/tuner question. I have a SF3 tuner with custom dyno tune for the auto ECU. Can I save this tune to the SF3, set the auto ECU back to stock, and load my tune onto a new 5 speed ECU? Obviously I have to have the dealer address PATS if I swap the ECU.
What functions are different between the auto and 5 speed ECU? Is an ECU swap even necessary, or can a tuner simply disable the auto functions?
Thanks
-Leather shift boot
-FRPP Shift knob
Thanks
