Auto Transmission Question
  • Thread starter Thread starter hh3
  • Start date Start date Dec 6, 2004
H
hh3
Concord, Ca
Dec 6, 2004
  • Dec 6, 2004
I'm in the process of rebuilding the 351W in my 69 Mach and I'd like suggestions on a Transmission replacement. It currently has the "weak" stock FMX and I'd like to upgrade. Any suggestion on a "clean" replacement that I can drop in without a lot of other modifications? Thanks, in advance for the help.
Max Power
1,774
St Paul
Dec 6, 2004
  • Dec 6, 2004
Probably a C4 would be the easiest. Not sure if you need a new flexplate and crossmember, but all auto 302 Mustangs in 69 came with a C4, so parts should be pretty easy.
Stang_1973
565
9
38
San Antonio, Tx.
Dec 6, 2004
  • Dec 6, 2004
I agree the C4 in its stock form can handle about 350 HP easily. If you beef it up it can handle alot more. It is also alot lighter than the FMX or C6 and has less power loss. You can put a shift kit in to make it have nice crisp or hard shifts, or turn it into a full manual. This costs less than converting a A/T car into a manual car.
302 coupe
1,952
Macon, Ga.
Dec 6, 2004
  • Dec 6, 2004
there's nothing weak about an FMX, they're good trannies. The only problem is the lack of aftermarket support. If you just plan on a mild rebuild, or a shift kit and converter upgrade, the FMX will be just fine. Its heavy, but thats the only real downside. I'd stick with it if I were you. Strengthwise, its between a C4 and a C6, ditto for parasitic loss. Save yourself the hassle of changing parts and stick with it.
G
GaPonyFarm
663
Columbus, GA
Dec 7, 2004
  • Dec 7, 2004
I absolutely agree with 302 coupe! There is nothing weak about an FMX and anyone who says different has never owned one and abused it. It is heavier than a C4, but you can race it all day, without worrying about the heat damaging it. Rebuild the FMX... you won't be dissatisified.
D
D.Hearne
11,730
south louisiana
Dec 7, 2004
  • Dec 7, 2004
I second that, there was nothing weak about the FMX. I've heard numerous cases where for somereason or other they had been run dry to the point where they quit pulling, then refilled and run some more. try that with a C4. As for a C4 handling 350 horses, I've gotta disagree, I had a heavy duty one in a 69 van behind a 200 horse 302 and in the ten years we had it, we had it rebuilt 5 times.
H
hh3
Concord, Ca
Dec 7, 2004
  • Dec 7, 2004
Guys, You talked me into it. I just ordered the master rebuild kit and the shift kit for the FMX. Thanks for the input. You probably saved me a lot of pain.
rbohm
6,698
550
204
tucson,az
Dec 7, 2004
  • Dec 7, 2004
i also agree witht he fmx being a strong tranny, but heavy.
as far as a C4, i have run one very close to dry, and still was able to tow a car and not have the C4 break. a C4 will handle about 300hp without upgrades and more when properly upgraded. one more thing, the fmx was the basis for the aod which is also a strong, but misunderstood tranny. if you have a 164 tooth flexplate with the right converter bolt pattern you can swap an aod in place real easy.
DarkBuddha
2,215
Seattle & Tampa
Dec 7, 2004
  • Dec 7, 2004
Well I'm glad other folks chimed in about the FMX being a good tranny... It is heavy, but it's a good performer. It's the evolution of the old original Ford Cruise-omatic, and was used as the basis for the late model AOD & AODE. The FMX is a great performer, stronger tranny than a stock C4 and will hold up as well as a stock C6. The iron belhousing is what makes it heavy, but it also provides better protection should something let go. The only thing that sucks is that it is a serious power robber. Still, if I hadn't upgraded to the AOD, I would've gladly stuck with my FMX forever.
Go FMX!
D
D.Hearne
11,730
south louisiana
Dec 7, 2004
#10
  • Dec 7, 2004
  • #10
Iron bellhousing? Where'd you find that antique? Most FMX's Ive seen had aluminum bells, most had aluminum tailshaft housings too. only the main case was always iron.
DarkBuddha
2,215
Seattle & Tampa
Dec 8, 2004
#11
  • Dec 8, 2004
  • #11
Damn, I knew that... iron case, not bellhousing. I gots . Damn, imagine how heavy it'd be with a damn iron bellhousing!
K
khsmach1
Dallas, TX
Dec 27, 2004
#12
  • Dec 27, 2004
  • #12
What if your goal was a 350+hp engine for street/strip purposes? What tranny would be needed for that type of an application?
302 coupe
1,952
Macon, Ga.
Dec 27, 2004
#13
  • Dec 27, 2004
  • #13
a C4 would be preferred in that particular scenario. However, if the car already had an FMX, I'd leave it in place as it should hold up fairly well behind a 350 hp engine.
D
D.Hearne
11,730
south louisiana
Dec 27, 2004
#14
  • Dec 27, 2004
  • #14
The FMX was the transmission of choice for Ford behind the 351 Clevelands, think about it. Also was used behind the 390's in the early 60's. I'f you've got one, keep it. If you don't then get a C4, but don't expect it to last forever
10secgoal
2,801
San Diego
Dec 28, 2004
#15
  • Dec 28, 2004
  • #15
Mine had an iron one. USE A JACK. Thems sum heavy sons a .......
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Paint in engine bay questions
  • B0udreaux
  • Feb 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 27, 2026
AeroCoupe
