First of all, I want to say thank you to everyone! I have received a tremendous amount of help on all of my Mustang questions. This is a great resource!
I was wondering if anyone has any links or information on the Autolite 4100 carb.
Specifically which of the two screws on the front of the carb are for idle mixture and which is for high-speed mixture.
Also, I don't know if you can tell much about the color of the plugs insulators, but I pulled one last night and the insulator was just about all white. Had just a small bit of yellow on it. No deterioration of the electrodes that I could tell though.
I have a 289 that runs a bit rough (like it is missing or something) while going down the road most of the time.
Thanks - Paul
Thanks - Paul
If he needs to have the idle screws out that far, he needs to check the choke, and I'll just bet with all that pumping, the fast idle cam isn't working properly. Ideally, he needs 1 pump to set the choke and that in turns lets the engine idle at the prescibed rpm until it starts to warm up. You with me?
