Right now I'd just settle for an engine that runs smooth once it is warmed up! The dang thing seems to act like it is flooding or starving or like the plugs are fouling whenever you try to hold the engine speed at a constant rpm. Then when you press the pedal down it jumps back to life again. The plugs all look like they should.
I'll tell you too that when I first started it tonight, it required about a 1/16th of an inch opening or less for the choke to keep the car running and that was when I used my finger to get the butterfly to stay at that position. And it was such a precision opening that I doubt the carb could ever be adjusted that accurately to maintain the engine. There is just too much play in all of the linkage...
So, I'm giving up on the hopes that I'll ever have an engine that you could pump once and turn the key and the thing would just warm up on its own and adjust idle speed accordingly without the need for pumping the pedal.
Like I said before, I'd just be satisfied if I could get in and drive it without the sensation of "running out of gas" whenever I try to keep a constant speed. I reset the idle mixtures back to 1 3/4 turns out from fully seated and that seemed to help when the engine was cold but not once the thing warmed up.
And I don't know if it could be that the coil is going faulty once it warms up but it didn't feel that warm on the outside of it after I turned the engine off.
I am just getting so frustrated!!!
I used to have a 67 t-5 with a 289 in it and that thing ran like a sewing machine. I don't understand why this one is being so damn finicky.
What's your best guess on my "out-of-gas" sensation that I am getting: Fuel-Delivery or Ignition related? And what's the best (least expensive) test for either?
