I was looking at the PDF file for the Autometer Wideband O2 gauges because I plan on installing one this winter. I have one question, where is the WOT switch on our mustangs?
There are several 'Strategies' the ecu uses to control fuel/timing.
Cold Start
Warm Start
Part Throttle
Wide Open Throttle
The ecu switches between these Strategies on its own. There is no manual switch per se.
Does that help, or make things clear as mud?
jason
Don't the O2s get cut out at WOT? I know the MAF has the relay on the fenderwell under it that is a WOT cutout is there one for the o2s? Thought maybe thats what he means.
If you don't have a tuner, then you may not need a WB...I am not sure I quiet understand. The wideband O2 sensor needs a WOT switch so I can recall the wideband AFR.
I am starting to question if I need the wideband O2 sensor. I did not tune my stang myself (as of right now I do not plan on diving into tuning), but it was professionally tuned using a wideband O2 sensor and dyno. Would it be good for monitering or once its tuned the AFR should not change?
I believe I have the performance modifications that would require a wideband O2 though. 331 N/A HCI combo (361 rwhp, 370 rwtq), with a good compression ration of 10:1 so I add a supercharger down the road (small amount of boost nothing over 12 psi).
No need to apologize... That is a VERY GOOD thing to stay focused on!Sorry it took so long for me to reply, college is taking over my life....
Any chance any of you could point me to a good post explaining open loop, closed loop? apparently I need to reread things.
You could hook up the WB to a digital gauge on the dash, but there is no need to run the WB signal to the ecu.
If you haven't changed anything on the car, then the tune should still be 'good'
Hope that makes more sense...
jason
Yup sure did, thought one of those things got cut out in OL thank u much for clearing that up.
