Axle Moving in and Out?
  • Thread starter Thread starter onefstsnake
  • Start date Start date Apr 17, 2007
onefstsnake
792
Northern VA
Apr 17, 2007
  • Apr 17, 2007
Well Ive had my 31 Spline 5 Lug axles in for a while now.
But when I had it on a jack a while back I noticed you can pull/push on the wheel and the tire/wheel move in and out maybe 1/4" and it makes a clunk noise.
Im guessing its just some play around the C clips?
Obsol3te
106
Apr 17, 2007
  • Apr 17, 2007
It's normal don't worry about it.
The c-clips will hold the axle in place, and the drums hold the c-clip in place.
TRWXXA
190
RIGHT BEHIND YOU!!!... Made you look.
Apr 17, 2007
  • Apr 17, 2007
A little in/out movement is normal. But if it REALLY is 1/4", that's a bit too much. It should be less than half that.
It's possible that the differential cross pin is worn. You might want to check it, and/or replace it, and the cross pin retaining bolt.
4G-KDMP
935
CA
Apr 17, 2007
  • Apr 17, 2007
they all have just a little bit of movement.
jtfairlane
468
  • Apr 17, 2007
Do you hear loud banging noises coming from the rear when you go over potholes or into and out of lips in parking lots? If so, than you may be experiencing what mine is, too much wear in the C-Clips.
onefstsnake
792
Northern VA
Apr 17, 2007
  • Apr 17, 2007
well the moser axles I used to have had an O ring around the C Clip slot.
The new axles I have dont have this.
Its probably not 1/4" but It definately moves.
I did noticed the C clips had some wear. But there werent any deep grooves.
HISSIN50
34
129
Apr 17, 2007
  • Apr 17, 2007
My guru buddy MM is doing a rear end swap and we were chattin about it. He had a very good point about this stuff. Because a little bit of slop feels like a lot, you really need to set up a dial indicator to measure the endplay. This takes the subjectivity out of it.
Good luck.
onefstsnake
792
Northern VA
Apr 17, 2007
  • Apr 17, 2007
first I would need to buy a dial indicator. lol
The rear end just felt funny when driving and I thought it might be the axle moving in and out.
But I also noticed that the top of the diff housing is like 3/4" away from the pinion snubber, so Im pretty sure I need to trim the snubber. And I believe the FMS driveshaft is rubbing on something too.
Modular2v
3,222
23
99
oklahoma
Apr 18, 2007
  • Apr 18, 2007
dont worry about it!
352Ford2
393
Seattle,WA
Apr 18, 2007
#10
  • Apr 18, 2007
  • #10
Their is a Ford spec on alowable axleshaft endplay is, I can't rember what it is, but1/4 is way too much. With excessive play you are much more likly to have a c-clip walk out and have your wheel/axle come off while driving (don't laugh I have seen it happen many times)
their are thicker c-cips to fix this. Are you sure the c-clip o-rings are on the axleshaft?, lack of those will cause this issue as well.
on a performance note if you are a conehead or an open track guy, this really messes with brake performance,
9" ends for the win!
fix it so you don't kill yourself or anyone else on the road
T
tripleblackragtop
12
Royal Oak, MI
Apr 18, 2007
#11
  • Apr 18, 2007
  • #11
Service spec is 0.030" for axle end play. Get a dial indicator and measure it. 1/4" is alot more than that. Three problem areas to look at:
The cross pin in the diff has been beaten down where the axle makes contact.
The C clips have been been beaten down. Last time I measured one though, I think they were ~ 0.150" thick. Not enough to account for .250" endplay.
With a stock type diff, the clutch plates in the Traction Loc could have worn out. I'm not familiar enought with the Aurburn Pro to know if any wear could increase axle endplay.
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Tuesday at 10:26 PM
AeroCoupe
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
