B&M Supercharger Questions!
Stangit50
I was on craigslist and found a B&M supercharger setup for 7lbs for 302s. It looks like a Carb setup but I was thinking of using a spyder efi intake and then an elbow ontop to bolt the throttle body to.
Anyone have any info on these? Would my idea work?
Sent from my MB855 using Tapatalk
Hope it comes with a new hood too....cause there isn’t any way that's clearing a stock or low cowl induction hood with that old roots blower on there and a spyder elbow.
The B&M chargers use the old strait cut Eaton rotor profile. Not bad, but not nearly as efficient as the modern 60-degree twist rotors and cases found with later Eaton’s. Should get a stock Mustang into the low-13's pretty comfortably though. It'll be pretty noisy too so be prepared.
If you want an old school "nostalgia" look and feel, go for it. If you want a performer.....look into a Kenne Bell.
