Back to back fox versus 94-95 TB dyno results inside!!!
Killercanary
The car that set the bar.
Altoona, PA
Yes, I finally did back to back dyno pulls comparing a fox style TB setup to a 94-95 setup. We've all wanted to see the results of such a comparison and I did it today. I tried to minimize the differences between the two pulls as much as I could. The only change between each pull is the TB and inlet elbow, I used the same air filter and inlet tube on both setups. The fox TB was a 75mm and the 94-95 setup was a 65mm. I would have liked to do 75 on both but I didn't have a larger 94-95 one to do it with. testing was done on an AWD dynojet dyno. Obviously the engine has loosened up a little since the last time I dyno'd it as I have more miles on it now. It was virtually brand new when I dyno'd it last. I will be dynoing the car again in a few weeks after I put on my new AFR 185 comp heads, probe shaft mount rockers, MAC 1-3/4 ceramic coated headers, and Dr. gas 3 to 2.5" X pipe that I just bought from a member here.
On the dyno:
Here's what everyone wanted to see... I'm convinced that the fox is worth more power, even with the difference in size between the TB's. The car was run at FULL temperature (190*) with 90* inlet air temps on both setups, no ice or shortbelts were used. These are true unaltered results. Run 2 was the fox TB, run 3 was the 94-95 style. The car made 355/365 STD last year with the 94-95 setup. The graph is hard to see, I'll try and get better scans later.
SAE
STD
I can't wait to see how much power I see with the new heads and exhaust.
I have to say thanks to the great students and staff at Wyotech in Blairsville where the car was dyno'd.
what you can't see and feel over the internet is the throttle reponce is sooooo much better, that i would do it with less gains for the better looks and chance i might be able to make somemore boost
This comparison is about like comparing Fox body headers to SN95 headers, but oh yea the Fox body headers are long tubes and the SN95 ones are only shorties. I don't even see why this was done unless you are doing the swap and just wanted to make a thread.
Also if someone is doing this mod (sn95 TB to Fox TB) in hopes of going faster then they have alot to learn...
Damn good post. Thanks for doing the comparo. It would have been really nice to see an = size t-body to = size t-body but it is at least a back to back of a non-stock size sn95 style to fox style...too bad no one had a 65 fox one laying around.
If your looking to get every ounce of HP 8.6-ish hp is not bad. Its not earth shattering to the point your stupid for not making the switch...but some people spend several hundred more to gain the same amount or less (ie. non PI cam swap in a 96-98 for instance).
The biggest factor if I was to make the swap is the fact it is so much cleaner under the hood with the much less "in your face" t-body.
rob i would think that too, but the guys that have done this with a blower seem to make more boost for some reason . i'm still running the stock vortech discharge which is more of a joke than the elbow for the intake.where is charlie? he did this swap already
Less restriction = less back pressure = less boost:shrug:
I must agree with rob here.
Troy not to rain on your parade but as Rob already pointed out, boost is just a measuremaent of restriction when you really break it down. Now if your telling me some guys are seeing more boost with the swap, than guess what? that would lead me to beleave that the fox conversion is more of a restriction and the only real benifit is the increased throttle responce brought on by the different arc and ramp rate of the throttle arm. I still think the dyno #s show nothing as the different size T-body could be responcible for the minimal gain. Untill I see a better comparo I will stick with the sn set up.
that would lead me to beleave that the fox conversion is more of a restriction and the only real benifit is the increased throttle responce brought on by the different arc and ramp rate of the throttle arm..
Good thread here :nice:
You usually see the "throttle response" phrase used in these threads :)
Like 95 opal ... I've always thought the different rate of opening of the
throttle body blade has a lot to do with that :scratch:
Just a thought :shrug:
Grady
