Backfire
  • Thread starter Thread starter geostang351
  • Start date Start date May 11, 2005
geostang351
946
Danb., CT
May 11, 2005
  • May 11, 2005
Hey, I just started my car after a AOD swap. No exhaust hookup right now, just open headers
The gas tank is pretty much bone dry but it started and ran rough! Whenever I let go the accel. it backfired hard. What is the reason for the backfire? What exactly IS a backfire?
G
grego37
576
Fresno CA
May 11, 2005
  • May 11, 2005
check all your vacuum lines, maybe you left one un-hooked
geostang351
946
Danb., CT
May 11, 2005
  • May 11, 2005
I did have one open. It was the old C4 vacuum hose, but as usual, nothing is that easy and it still backfired.
geostang351
946
Danb., CT
May 12, 2005
  • May 12, 2005
Could it be the old fuel?
67coupestang
509
  • May 12, 2005
mine backfires every year when i pull it out of storage. bad fuel it usually clears up after carb cleaner, new fuel and about 30 miles for me
geostang351
946
Danb., CT
May 12, 2005
  • May 12, 2005
Thanks.
Does anyone know what a backfire is?
69Rcode_Mach1
1,473
Salt Lake City, Utah
May 12, 2005
  • May 12, 2005
A little Off topic but here goes.
Hey Geo stang what kind of power are you making with that combo? I am just curious as to where that cam really picks up since it is what I am putting in mine. I don't exactly know the answer to your question sorry.
krash kendall
1,258
Aldergrove, B.C. Canada
May 12, 2005
  • May 12, 2005
Raw uncombusted fuel exits through the exhaust port and is ignited causing the backfire. This can be caused by overcarburation, bad ignition or points, or in your case little or no backpressure. When my points crapped out, both my new mufflers were destroyed when they unexpectantly (yeah right, like I didn't see it coming) exploded.
geostang351
946
Danb., CT
May 12, 2005
  • May 12, 2005
I'll say you've got two out of three. My mixture is definetly more on the rich side. I have a petronix module so points aren't an issue and obvious not exhaust right now. Its just SO scary when I start it with open headers and then it bafckfires. Feels as though the whole car is about to explode!
69 - It powers up at about 4000 rpm but I really don't get on it too often. Maybe afraid of blowing it up or something breaking and running off the road. I got this cam more for its bark then bite. It sounds awesome.... very throaty. I think if the dog "sounds" mean, it must be mean. In short, if it sounds fast (to others) it must be fast
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
P
Progress Thread New To Me 1988 GT - trying to set up vacuum lines for upper intake question
  • pindude80
  • May 6, 2025
  • 9 10 11
15K
Fox 5.0 Mustang Tech Mar 28, 2026
pindude80
P
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
