91 mustang lx 5.0 2nd and 3rd wot around 2500 and above can't get out of its on way backfires then launches and back fires again shift to 3rd same thing can smell gas where do I start? Plugs,for, where let me know please thanks
122k stock yes original 5 0Need more info.
How long have you had the car?
Miles?
Originally a V8 car?
Any other modifications?
Codes I got were 11 33 and 13Codes first:
It's likely in limp mode.
The throttle position sensor is probably bad. Your code check will help to confirm.
Engine off
It came up as a 4Can you run the engine running codes as well? Those will likely be more informative
Running codesWasn’t a valid test.
Do the koeo and cm codes. Once done, start the engine. The idle should go up, display a 4 or 8 and the start spitting out codes shortly after. A pass is code 11. No codes, or no code 11 and it was not done correctly.
Plus KOEO codes 13 and 33Running codes
11
22
44
41
These ECU’s are known for the internal capacitors going bad. They can be repaired. Some diyers have been successful at repairing them. I tried but it didn’t work for me. I then sent it in to an exchange service. You send yours in and they either repair it or send you another that’s been repaired. I’ve had good luck with this service. So, “if” it’s your ECU acting up you could consider this pathSo I'd need to get a new pcm if the firmware is defective correct
Unless the diaphragm is torn then it's a vacuum leak.Code 33 is the EGR. Wont affect how car is running
