Backfiring through intake and cannot check codes
  • Thread starter Thread starter webshot
  • Start date Start date Jul 19, 2008
  • 3
First Prev 3 of 3
W
webshot
738
Yay Area, California
Aug 30, 2008
#41
  • Aug 30, 2008
  • #41
got it thanks, that test yielded a low pressure reading too. Looks like I will be dropping the tank. Any input or gotchas on that now? Again thanks.
The pressure was extremely low. Is it possible for the fuel pump to only be a little bit good? The car runs great outside the backfiring. Just wondering if I should be looking for some other culprits while I am doing this.
Input appreciated
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 31, 2008
#42
  • Aug 31, 2008
  • #42
Input appreciated
Here are some useful tips...
I have done the tank removal three times, and the main issues are getting the car up on jack stands and getting the gas
out of the tank. DO NOT try to do this job without jack stands. Becoming a pancake is not part of the repair process.
Pumping out the old gas:
If the old pump still works, you can use it to pump the tank out.
1.) Separate the pressure line (the one with the Schrader valve on it) using the fuel line tools.
Look in the A/C repair section for the fuel line tools. They look like little plastic top hats. You will need the 1/2" & 5/8" ones.
The hat shaped section goes on facing the large part of the coupling. Then you press hard on the brim until it forces the
sleeve into the coupling and releases the spring. You may need someone to pull on the line while you press on the coupling.
Use a piece of garden hose to run from the pressure line to your bucket or gas can. Make sure it is as leak proof as you
can make it. Fire and explosion are not part of the repair process...
2.) Jumper the fuel pump test point to ground.
Turn the ignition switch to the Run position. the fuel pump will pump the tank almost dry unless the battery runs down first.
Some 5 gallon paint pails lined with garbage bags are good to hold the gas. The garbage bags provide a clean liner for the
pails and keep the loose trash out of the gas so you can reuse it. If you decide to use a siphon, a piece of 1/2" garden
hose stuck down the filler neck will siphon all but a gallon or so of the gas.
Remove the filler neck bolts and put them in a zip bag. Disconnect the supply & return lines by removing the plastic clips
from the metal tubing. If you damage the clips, you can get new ones form the auto part store for just a few dollars.
I have used tie-wraps, but that is not the best choice. Then you remove the two 9/16" nuts that hold the T bolts to the
straps. Put the nuts in the zip bag with the filler bolts. Pull the plastic shield down and away from the tank.
Once the tank drops a little bit you can disconnect the wiring for the pump & fuel quantity sender.
The pump and fuel gauge sender assemblies comes out by removing a large metal ring that unscrews from the tank.
There is a separate mounting/access plate for the fuel pump and fuel gage. You are supposed to use a brass punch to tap
on the ring so that you don't make sparks. Look closely at the rubber O ring gasket when you remove the fuel pump or
sender. The pump assembly requires some twisting and turning to get it out the hole.
Look very closely at the electrical wiring. The stock fuel pump wiring can overheat and melt the insulation. Mine had some
really crummy plastic tubing slid over the quick disconnects. If the wires ever got together, there would be sparks inside the
fuel tank and no more Mustang. I eliminated the splice in the middle of the wiring and went straight from the pump to the
feed through connectors for the wiring. It required some soldering and crimping of new tabs on the wires, but it made a
neater job.
Inspect the pump mount to metal tubing bracket. Mine broke and I couldn't get it to solder back together. I drilled a small
hole for a machine screw & self locking nut to hold the clamp and bracket together.
The pump is easy to get off the mount but is somewhat difficult to get back it the tank without damaging the sock filter or
tearing it on the tank baffle. When you install the metal ring that holds the pump in place, watch out for the gasket O ring.
Some RTV may be helpful if the ring is not in excellent condition.
The tank to filler pipe seal is a large rubber grommet. Inspect it for hardening, tears and damage. At $20 from the Ford
dealer, it might be a good idea to replace it.
I used a floor jack to help lift the tank back in place. You may find that it is the only time you really can make good use of a helper.
W
webshot
738
Aug 31, 2008
#43
  • Aug 31, 2008
  • #43
Thanks....I will be tackling this next weekend will update!!
W
webshot
738
Aug 31, 2008
#44
  • Aug 31, 2008
  • #44
While I am at it. should I get a aftermarket fuel pump or just a OEM replacement?
W
webshot
738
Sep 3, 2008
#45
  • Sep 3, 2008
  • #45
bump......just making sure I shouldnt but like a Walbro255 or something while I am at it. Or is it just better to get a OEM replacement. Will be starting the process tomorrow so hopefully can get input today.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 3, 2008
#46
  • Sep 3, 2008
  • #46
neater job.
W
webshot
738
Sep 3, 2008
#47
  • Sep 3, 2008
  • #47
Thanks, I got your first message about how to go about it. And it seems very concise. My questions is along the lines of what type of replacement unit I should get. Since I am doing it should I go aftermarket, or is that overkill or ill-advised? Will the standard stock unit suffice? Car is bone stock.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 4, 2008
#48
  • Sep 4, 2008
  • #48
Use a pump wiht 155LPH or higher rating. The regulator will keep the pressure where is should be and return the excess fuel to the tank. Buy a name brand pump and you should be OK.
W
webshot
738
Oct 4, 2008
#49
  • Oct 4, 2008
  • #49
Just a update, after all of this it turned out to be the stinking fuel filter...lol. A 10 buck part. But I wanted to just come back and thank all of you guys for your input and I am sure that this thread will help others as well.
  • 3
First Prev 3 of 3
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
  • brandyn200
  • Jun 20, 2026
AeroCoupe
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
P
Progress Thread New To Me 1988 GT - trying to set up vacuum lines for upper intake question
  • pindude80
  • May 6, 2025
  • 9 10 11
16K
Fox 5.0 Mustang Tech Mar 28, 2026
pindude80
P
