Bad Bearings In Rear End
  • Thread starter Thread starter The_Dude
  • Start date Start date Jun 26, 2012
The_Dude
137
Western Oregon
Jun 26, 2012
  • Jun 26, 2012
Took my '91 in for an alignment and inspection. The chassis shop says that, at least, my axle bearings are bad and a good chance the rest are bad too. They want $600 to rebuild and say I'll probably need $400 worth of axles. Do the axles typically go bad with bearings? How hard is it to replace the axle bearings? The parts don't seem to expensive at latemodelresto.
9
92 LX
78
  • Jun 26, 2012
How do they know your axle bearings are bad? Is the rear making any noise? Something doesn't seem right, you shouldn't need new axles. Maybe just the seals are leaking???
I'd get another opinion.
The_Dude
137
Western Oregon
Jun 26, 2012
  • Jun 26, 2012
They put it on a lift and say they're making noise. The shop has done a lot of work for me in the past. They're not cheap, but I do mostly trust them.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jun 26, 2012
  • Jun 26, 2012
You generally wouldn't know if the axles are bad unless they were out. Looking for abnormal wear, or pitting on the bearing ends. I'm thinking that they're guessing that the axles will be toast based on the condition of the bearings. Neither one of you will really know for sure till it's apart. Sounds like they're hoping for the best, but trying to prepare you for the worst?
The_Dude
137
Western Oregon
Jun 26, 2012
  • Jun 26, 2012
Yes, that was my impression as well. They did say that, more often than not, the axles do go bad with the bearings.
The_Dude
137
Western Oregon
Jun 26, 2012
  • Jun 26, 2012
If it's just the axles and outer bearings, I probably rather do that work myself. If it's the inner bearings too, I think I should replace the 2.73 gears with 3.55s at the same time. I think the shop is going to kill me on parts if I have them do it all.
boostfrk
712
69
59
Colorado
Jun 26, 2012
  • Jun 26, 2012
I replaced my axle bearings a couple months ago...only took a few hours start to finish and that was lollygagging around. Like Gearbanger said you won't know if the axles are bad until you pull them out. Look for scoring or pitting on the axle where the axle rides on the bearing.
rd
3,316
63
109
Ocean Springs MS
Jun 26, 2012
  • Jun 26, 2012
If it is the outer bearings, they make a repair bearing that has a sleeve to go over the worn part of the axle. Ask around at a parts store. Changing the outers is pretty easy.
What symptoms did you have. My 89 notch seemed like it had a noise from one or the other going around a corner, so I pulled the axles. They and the bearings were fine, so I put them back in. Just make sure theres enough gear oil in there.
2000xp8
SN Certified Technician
Aug 8, 2003
8,078
1,659
194
NJ
Jun 26, 2012
  • Jun 26, 2012
Here are my thoughts,
If you are going to mess with the rear at all, go all in.
New bearings, 31 spline axles with 03 cobra traction lok and 3.73 gears.
If the axle bearings are shot and you have driven on them a long time, likely they have worn down the axles, i know, i did it years ago.
If this started a week ago, i'd say you are fine.
Either way, do the rear once, and do it right.
You really don't want to pay to do rear work more than once.
No sense in digging in twice, and if you goto 3.73's while you are there, every penny will be worth it. Especially over 2.73's, it will feel like you have a new car.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jun 26, 2012
#10
  • Jun 26, 2012
  • #10
While I agree that would be a stout rear end set up, 31-spline axles are pretty overkill for most applications. The 28-spline units will hold up fine through most power levels. Only when he really starts hooking up is he going to need something more "robust". If the guy hardly ever see's the track and is making under 300hp he's probably never going to have an issue with the stock axles. Even with Drag Radials. The stock trac-loc with upgraded disks is probably fine too. No sense using a hammer to swat a mosquito when a newspaper will do?
I'm totally with you on the gear swap though.
The_Dude
137
Western Oregon
Jun 26, 2012
#11
  • Jun 26, 2012
  • #11
I mostly agree with you, but the budget is a problem. I'm currently up to my ears with a 5-speed conversion in my '69 convertible. Currently the plan is, if it's just the outer bearings, I'm just replacing those. If it needs more, I'll rebuild it all with 3.55s (I drive a lot of highway miles in this car and it will never see a track).
2000xp8
Aug 8, 2003
8,078
1,659
194
NJ
Jun 27, 2012
#12
  • Jun 27, 2012
  • #12
Well, if the budget is the issue, i still wouldn't just do the outer bearings.
If they are shot, the others soon will be and the rear takes like $40 worth of fluid and friction modifier, so you still don't want to do it twice.
If the axles are ok (and really the should be), change all bearings, rebuild the trac loc and change the gears. IMO you have to rebuild the traction loc, it would be ignorant to not do it while the rear is open, you will hate yourself if you got it back together with new fluid and it started the one wheel peel.
For the record, there is no mileage difference in 3.55's to 3.73's.
2000xp8
Aug 8, 2003
8,078
1,659
194
NJ
Jun 27, 2012
#13
  • Jun 27, 2012
  • #13
With you on that gear, my only thought is that 03/04 cobra traction loc's can be had pretty cheap with shopping and they are 31 spline, so if he had to buy axles might as well just get the cobra locker and 31 spline axles.
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Jun 27, 2012
#14
  • Jun 27, 2012
  • #14
$400 axles? Are they made of gold?
Moser axles are $250
http://www.latemodelrestoration.com/item/MOS-7993-28/79-93-Mustang-28-Spline-4Lug-Moser-Rear-Axles
Outer bearings and seals are $30
http://www.latemodelrestoration.com/item/AK-1563K/1979-04-Mustang-Rear-Axle-Bearing-And-Seal-Kit
The job is easy to do. Just need to rent a slide hammer from autozone and a bearing puller.
You won't even know if the axles are bad until you pull them, and even then you can go get a repair sleeve bearing at an auto parts store.
There are inner bearings as well, but if your rear end needs a rebuild, you can do this job with the install of new clutch disks and new gears.
Either way, if the shop wants to charge you $1000 to rebuild a rear end...well just order this
http://www.summitracing.com/parts/FMS-M4001SVT373/
Reactions: The_Dude
The_Dude
137
Western Oregon
Jun 27, 2012
#15
  • Jun 27, 2012
  • #15
They wanted $600, but that was without axles. I was searching for that rear end yesterday. I remember Ford Racing selling that rear for like $800, but that was 5 or 6 years ago.
Edit: I did find that one yesterday. It's for '05 and up. What needs to be done to make it fit a '91?
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Jun 27, 2012
#16
  • Jun 27, 2012
  • #16
They might still sell the 79-98 rear. Injust did a quick google search and thought that was it. Different part number
Sent from my iPhone 4S using Tapatalk
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Jun 27, 2012
#17
  • Jun 27, 2012
  • #17
Either way $600 to replace bearings only is excessive.
The_Dude
137
Western Oregon
Jun 27, 2012
#18
  • Jun 27, 2012
  • #18
As far as I can tell, no one sells the complete assembly anymore. You have to rebuild your old one.
The_Dude
137
Western Oregon
Jun 27, 2012
#19
  • Jun 27, 2012
  • #19
I had another guy look at it, (who I know I can trust), and it does need outer bearings and the axles are bad. He said the rest was in great shape. Against popular opinion, I'm going the cheap route with axle savers and outer bearings. This car only gets driven in the summer. The engine needs a rebuild, so after I do that, I'll rebuild the diff with new gears.
krazedstang
670
278
104
Streamwood
Jun 28, 2012
#20
  • Jun 28, 2012
  • #20
this post is depressing.... I want to beef up my rear end while swapping to a 5 lug and 4 wheel disc brakes. It's just to darn expensive for me right now and probably the next year
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Drive Shaft/Rear Diff Issue on 2014 GT
  • DudeStang
  • Jun 16, 2025
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech Jan 21, 2026
gkomo
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
