  • 1994 - 1995 Specific Tech
Bad clutch cable?
  • Thread starter Thread starter gumby5.0
  • Start date Start date Jul 12, 2009
G
gumby5.0
24
  • Jul 12, 2009
Ever since I got my mustang "rite" so I could drive it, I've noticed the clutch pedal feels like junk going into 1st and 2nd gear. Then today as I was pulling into the garage which is uphill so its pita with the way the clutch pedal feels, I went to drive it in and as I was doing so the drive train jerked a bit like i just dropped the clutch real quick and I couldn't get the car out of first gear easily. Any body think this is a clutch cable issue?
earleys94gt
1,223
Ashley, Ohio
Jul 12, 2009
  • Jul 12, 2009
Have you checked/changed your trans. and or clutch fluid recently?
G
gumby5.0
24
  • Jul 12, 2009
Yea I put 2.8 quarts in the tranny rite after I put it in a few weeks ago
G
gumby5.0
24
  • Jul 13, 2009
I left some details out. When the drive train jerked i was engaging the clutch. When I couldn't get the car out of first gear I had to press the clutch in twice to get it to come out. Also it can be a pita to get the car in first or reverse after starting it up, I have to keep using the auto adjuster on the clutch to finaly get it set rite so I can get going
HISSIN50
34
129
Jul 13, 2009
  • Jul 13, 2009
It's probably either the quadrant and pawl mesh is slipping, or the cable is letting go.
I would replace the quadrant with an aftermarket piece no matter what (you'll need a FWA too). Consider replacing the cable. If yours is actually ok, you have it as a spare if needed in the future. If it's not ok, you'd have to replace it anyhow.
I've lost a few clutch cables and every time, I initially got a loud pop and the pedal got soft with lots of freeplay. I would adjust the freeplay out and limp it home. The cable would keep fraying every time I used the clutch.
Good luck.
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Drivetrain Sticky clutch pedal
  • keel
  • Jul 31, 2025
Fox 5.0 Mustang Tech Oct 17, 2025
Mindseye007
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
