90Notch
You can run a larger cam and still pass smog. 5600 peak is about right for that cam but I still think torque should have been greater. Any chance you can post the dyno graph?
yellow5.0cobra said:it doesnt matter if the compression was that low, it will still have spunk and wouldnt lose 40hp.
210* wont ROB power, but its not the best constant temp.
If the computer threw a code, it would be in LIMP mode, aka, RICH condition.
You should be EASY in the 320rwhp mark, IF not a little more.(with a 5spd)
exhaust leaks DONT help, so fix those ASAP.
blown5.0 said:at a certain throttle position the eec goes into WOT and at this point the older eec uses a lookup table for injector pulse with, which is why you can tune the a/f ratio via fuel pressure or injector size, on the never eec's they are always using feedback to maintain a certain a/f ratio at these require a chip to set the new a/f curves.
blown5.0 said:My point being on older eec cars the injector choice is critical to good power, slapping 30# injectors on a stock motor will run good at part throttle as long as the mass air is cal'd right, but at WOT it will run way rich.
