Bad Injectors, or granatelli mas?
FSTRDNU
76
i went to summit, adn bought a tfs intake manifold, and a spacer, roller rockers, and a granatelli mas air meter, tuned for cold air, and fms 24 lb injectors.
with everything except the mas and the injectors on the cars runs strong, but when i put the injectors and the mass on, the car, idle surges, and dies, and it is very slow.
what could be causing this?
FSTRDNU said:
the box says its for 24lb,
should the fpr vac be connected, or disconnected?
should the stock fuel pump work ok for this?
The stock 88 LPH fuel pump will not supply enough fuel for 24 lb injectors. MInimum size is 112 LPH. Since a 255 LHP is only a few $$$ more, most guys go with the larger size fuel pump.
Fuel pressure is best checked at idle, with the vacuum line disconnected from the regulator. Set the pressure at 39 PSI, +/- 1 PSI. Either plug the loose vacuum line or hold your finger over it so it doesn't suck air and upset the idle.
FSTRDNU said:
are you saying that the fuel pump is not enough, even at idle, and thats making my car loose 100 hp?
No. You won't have enough fuel volume at WOT with an 88 LPH pump for 24 lb injectors.
